It is currently Sun May 24, 2026 9:06 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Sat Mar 25, 2006 7:59 am
So I've heard the KC helo doing streaming video during big events (WT O 2). They were working things out last night on MARS with WS P dispatch. I wasn't able to listen that close but it sounded like they were not having any trouble at all so it must be a new system. Any ideas if it's a signal we could see on like a R3?
-m
PostPosted: Sat Mar 25, 2006 8:16 am
Unless your R3 can do 6 GHz, no.
PostPosted: Sun Mar 26, 2006 12:03 pm
Try around 4940 - to - 4990 Mhz.
PostPosted: Sun Mar 26, 2006 6:50 pm
Check out WQCP992 at the FCC website
PostPosted: Sun Mar 26, 2006 9:51 pm
How about a hint -- to what I should be looking for ??
PostPosted: Mon Mar 27, 2006 6:28 am
It looks like the part that reads:
Path: 1 Frequency: 1
Frequency:
00006496.00000000
Upper Frequency:
Tolerance:
0.00025
Power Output:
EIRP:
42
Line Loss:
Emission Code:
Emission:
8M00D7W
1
Path: 1 Frequency: 2
Frequency:
00006505.00000000
Upper Frequency:
Tolerance:
0.00025
Power Output:
EIRP:
42
Line Loss:
Emission Code:
Emission:
8M00D7W
1
PostPosted: Mon Mar 27, 2006 6:57 am
I have a Bearcat 101. Can you tell me how to position the 16 switches to get that frequency? No really, are there receivers for this freq at the mil surplus places?
-m
PostPosted: Tue Mar 28, 2006 11:33 pm
Looks like King County is using the 6 GHZ band and Seattle PD is going to use the NEW 4.9 Ghz (Police Video Band). Anyway you look at it -- you will need a receiver that covers from about 4 to 7 Ghz. Most receivers I have seen -- are NOT surplus. They can be had -- but $$$$. As for Mark's Bearcat -- I'll see his scanner and give you a Whamo 10 with programming combs and a MS-1 Memoryscan. LOL :D :D
PostPosted: Wed Mar 29, 2006 6:09 am
I''ll raise you with a Digiscan 8 and, hold on, a Digiscan 16. What was the name of the thing that would go in the input of the car am/fm antenna and convert it with a crystal to a VHF freq.
-m
PostPosted: Wed Mar 29, 2006 2:08 pm
??? Tune-a-vertor ??. LOL --- :D :D :D My first unit. Cost $ 35.00. It was set for about 750 Khz AM to receive 155.97 mhz -- NO Squelch. What a dog -- but it worked.
PostPosted: Thu Mar 30, 2006 12:26 pm
Thats the one. Mu first radio was a GE taxi radio (with 12V battery and car charger) that had been retuned to 33.9 so I could hear SFD. I'm completely blanking on where SPD was before they moved to UHF
PostPosted: Fri Mar 31, 2006 12:47 am
Seattle FD was on 33.90 Mhz before they moved to UHF. Before that they shared a channel with Seattle PD around 2400 Khz -- AM.
PostPosted: Fri Mar 31, 2006 7:37 am
where was SPD before UHF?
PostPosted: Fri Mar 31, 2006 11:03 am
Heard rumors they used to split 155.190 with KCSO and a couple of others
PostPosted: Fri Mar 31, 2006 11:16 am
It's coming back to me. 155.25, 155.19 and I think two more.
-m
Users browsing this forum: No registered users and 16 guests
