It is currently Tue May 19, 2026 2:28 am
PostPosted: Tue Apr 20, 2004 3:26 pm
Hello all I've been listening to the VALL COM looking to hear KENT FIRE, and kent FIRE, I live a block or so from the pd station and fire stations, I'd just like to know whats going on around me! Or are they using the KCjail site, I don't hear arny thing onthe control ch. fro that site.
THANK YOU FOR any help
STEVE
GOD BLESS 73s
 Post subject: Kent FD/PD Talkgroups
PostPosted: Tue Apr 20, 2004 3:54 pm
First, it sounds like you may have programned your scanner wrong. If your only hearing the control channel, then you need to check and see if your scanner is programmed according to the manufacturers directions.
Also, you should only need to program the KC Similcast frequencies to listen in your area.
Are you trying to listen on a scanner capable of monitoring a trunked radio system? If not, then your going to have problems listening.
Once you get your programming situation straitened-out, here are the talkgroups you should be listening to for your area(Kent):
Fire-1: 38448 (Kent FD is dispatched by Valley Communications)
Fire-2: 38480
Fire-3: 38512
Fire-4: 38544
Fire-5: 30672
Fire-6: 30704
Fire-7: 30736
Kent Fire Admin.: 38832
Kent Fire Preven: 38864
Kent PD Primary: 37136
Kent PD Tactical: 37168
Kent PD Admin. : 37200
Those should get you started. If you're interested in more TG's check out the Intercept site for more info.
PostPosted: Tue Apr 20, 2004 9:25 pm
:lol: THANK YOU CAR, I'm using a BC250D I guess I should have been more clear I just wanted to confirm the C C ch. of 868.4250 I'm picking up the PD dispatch BUT nothing fore the fire or aid oh well thanks for helping.
> tow truck LOL
GOD BLESS 73s
Users browsing this forum: No registered users and 16 guests
