It is currently Fri May 08, 2026 6:16 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Oct 14, 2015 7:35 am
FlashP wrote:
site numbers are offset on some but I believe the control channel freqs are pretty good.
Some of us use the Trunk88 numbers, some use the Moto numbers... we really should standardize.
I use APX8000 numbers
PostPosted: Wed Oct 14, 2015 3:28 pm
I agree. Much as I would like to match the guts of the system, I think it will be less confusing for our users if the numbers match the scanner displays and monitoring software: the higher values.
PostPosted: Wed Oct 14, 2015 3:33 pm
Nick volunteered to fix it!
PostPosted: Sat Oct 17, 2015 12:44 am
So you guys want the Uniden numbers?
Unitrunker = Site 3 [3]
Pro96Com = Tower0103 [103]
So which format do you all want?
PostPosted: Sat Oct 17, 2015 12:55 am
The one the scanner says.
PostPosted: Sat Oct 17, 2015 2:18 pm
Yes, EPSCA = 3, Boeing Wide Area = 101. I could go with the P25 systems as 001001, as well.
PostPosted: Sat Oct 17, 2015 6:45 pm
Many thanks Dog for updating the King County .p500 files in the wiki.
The now live in my WIN500 program and the PRO-197 & PRO-106.
No problem with the name or phone # this time. Hi Hi !
PostPosted: Sun Oct 18, 2015 1:43 pm
So the KC/VC CC primary is 853.425 and the only alternate is 853.45?
PostPosted: Sun Oct 18, 2015 3:53 pm
Check the database, there are four freqs to program.
PostPosted: Sun Oct 18, 2015 6:21 pm
What database? Is that under "Database Search" or the Wiki?
PostPosted: Sun Oct 18, 2015 10:32 pm
OK- I found the 4 freqs in the WIKI.
Thanks!
PostPosted: Mon Oct 19, 2015 8:27 am
Yes, Database Search. You'll be able to glean the same info via the wiki--the King County Trunked System article will link you to the database.
PostPosted: Mon Oct 19, 2015 9:11 am
Thanks for the info. Maybe its my browser but I found the links for the freqs and the TGIDs on the King County Trunk System Article to be broken.
PostPosted: Mon Oct 19, 2015 12:21 pm
It wasn't just you. I fixed the links.
PostPosted: Fri Oct 30, 2015 8:27 pm
CAR wrote:
Nevermind. Just found info regarding my scanner on the site. Over and done with for my scanner (on KC's system). Procuring a new one soon. Recommendations?
APX7000 :D
You can also enable a full spectrum control channel scan on /\/\ gear, so, in the event of a reband, you will hear, but it'll take longer to find the system..
The radio will say 'out of range', but will resume normal operation when it finds a system matching the system ID you have programmed.
Not too shabby.
