It is currently Mon May 04, 2026 4:19 am
Post new topic Reply to topic  [ 447 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 30  Next
 Post subject: Re: WSP Radio Upgrade
PostPosted: Thu Jun 21, 2012 7:26 am
Warm beer.
PostPosted: Thu Jun 21, 2012 8:22 am
The id's The Ides of June
PostPosted: Thu Jun 21, 2012 5:28 pm
never mind, Munrow...
PostPosted: Sun Jun 24, 2012 9:12 pm
I'm starting to see what appears to be 700/800mhz open coil antennas on cars in Dist 5
PostPosted: Mon Jun 25, 2012 6:22 pm
Yuck! Base loaded 5/8 ~ work so much better... :cry:
PostPosted: Mon Jun 25, 2012 7:24 pm
As seen here. Same general type:
http://www.kimatv.com/news/local/WSP-Ma ... 87275.html
Cars here are getting both 800 and VHF antennas and all 5/8ths waves are going away. I feel bad for the troops...those 5/8ths wave antennas are much better...
PostPosted: Mon Jun 25, 2012 8:07 pm
These were mounted forward ahead of the current VHF 5/8, not sure whats going on.
PostPosted: Tue Jun 26, 2012 1:11 pm
The IWN is actually a very slick system....lucky for WSP to get on such an agreement and even supplementing it with 700/800...yes I know bad for us listeners but they DO have access to one of the best VHF P25 trunking systems in the west!
PostPosted: Tue Jun 26, 2012 2:24 pm
They are not looking for gain in the antenna. They are looking for pattern. Gain isn't necessarily a desired characteristic of a multi site system.
PostPosted: Tue Jun 26, 2012 5:02 pm
Open coil verses something like a B8063.. Ill take the base loaded antenna for several reasons... http://www.tessco.com/products/displayP ... ventPage=1
But biggest problem I see is systems that are engineered without taking into account the mobiles... or when they are the mobiles are never built to the engineering standards or installed by some wannabe that has no clue that you cant just wing it...
PostPosted: Tue Jun 26, 2012 5:11 pm
The IWN is built for mobile and portable coverage though.
PostPosted: Tue Jun 26, 2012 5:29 pm
Mobile= anything that is not bolted down... Same thing... If I figure that your users should be using MT1500's (big radio big ground plane) on your analog system and then you show up with EX500's (Little radio little ground plane)... well-
But if your lucky enough to be on a system that has more than 80% portable inbound coverage in your area... Congrats!
You probably don't use a portable in your car if you have a mobile... If the mobile is installed incorrectly- you might have about the same coverage results as your portable.
PostPosted: Thu Jun 28, 2012 12:00 am
So.... are they going to program 'media' radios? Or get sued like every other dep't that went full crypto?
PostPosted: Wed Jul 11, 2012 8:43 pm
I've had my Pro-106 hooked up to pro96com 24/7 for the past month and something interesting just popped up. I usually monitor the Seattle-North (170.9375, T-107) site as it seems to have the most activity and this just appeared:
"01-2160","c",775.50625,805.50625,0"
A 700MHz site, usage is control only, with no hits. When I tune to the frequency however, I'm unable to pull a signal of any kind with any antenna.
Side note: I've logged about 172 TG's and 1363 radios if anyone wants to see the full pro96com files. All TG's are in the 13xxx range.
Thurston County, WA
PostPosted: Wed Jul 11, 2012 9:36 pm
I'm also currently monitoring site 107 and not seeing that, nor are 108, 110 or 164 showing that as a neighbor anywhere.
BTW, site 107 is nowhere near North Seattle; it's in Kitsap County.
