It is currently Fri May 22, 2026 4:16 am
Post new topic Reply to topic  [ 736 posts ]  Go to page Previous  1 ... 32, 33, 34, 35, 36, 37, 38 ... 50  Next
PostPosted: Tue Mar 06, 2018 11:19 pm
So is it trunked or conventional?
PostPosted: Tue Mar 06, 2018 11:42 pm
Yes.
(Cap+)
PostPosted: Tue Mar 06, 2018 11:47 pm
LCNs?
PostPosted: Wed Mar 07, 2018 12:32 am
Don't use LCNs to track the system.
PostPosted: Wed Mar 07, 2018 12:39 am
The scanner does
PostPosted: Wed Mar 07, 2018 11:28 am
The scanner does
In trunking mode only... ;) It's only 4 frequencies so probably won't matter much anyway...
PostPosted: Wed Mar 07, 2018 12:01 pm
The scanner does
Does if you want to follow a conversation
PostPosted: Wed Mar 07, 2018 4:07 pm
The scanner does
I need to send my TRX-1's back for repair.
In the first TRX, I entered all the licensed Ilani freqs with open TS/CC/TG. I had several hundred hits, and, after sorting them by TGID, was able to hear plenty of conversations. This also worked well for tracking RIDs, as I kept seeing RIDs on TG-10 appear on TG-17, though they never called it anything. Each transition was accompanied by "switch", so obviously they have already prearranged 17 as a c/c channel.
In the second TRX, I built a new trunking system, assigned it all the licensed frequencies and assigned it a wildcard TGID. Again, it recorded several hundred hits which I was able to sort by TGID and follow.
If only I'd had the LCNs, I'd have undoubtedly been able to follow conversations and ascertain the talkgroup usage. Oh well, live and learn.
Taco, you went right past this casino twice two weeks ago- did you have any luck with it using your coveted DSD+?
PostPosted: Wed Mar 07, 2018 4:21 pm
DSD+ doesn't do LTR. Unless Grand Wolf switched...
PostPosted: Wed Mar 07, 2018 4:28 pm
Great Wolf isn't a casino. You're avoiding the question.
PostPosted: Wed Mar 07, 2018 4:32 pm
PostPosted: Wed Mar 07, 2018 4:34 pm
But yes, DSD+ can track trunked system, show affiliations, text messages, play remote monitors, etc.
PostPosted: Sat Mar 10, 2018 3:08 pm
VTAC-12 Auto Theft Task Force surveillance + air support
3.9.18
Recordings: https://www.dropbox.com/s/h54nw5w4z4hkm ... .zip?raw=1
PostPosted: Sun Mar 11, 2018 3:15 pm
Clark, Cowlitz, Multnomah... I lump them all in the "Paddle-Faster-I-Hear-Banjos" category.
Ive heard talk you have a certain “affinity” for banjo music and banjo players.........
PostPosted: Sun Mar 11, 2018 3:58 pm
Bold talk from the guy who spent all his free time in the backwoods of Lewis County this weekend...
Users browsing this forum: No registered users and 30 guests
