It is currently Sat May 16, 2026 3:37 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: WSP TRS Changeover
PostPosted: Tue Dec 09, 2014 7:12 pm
They're also running Seattle South Area on the Grass Mtn IWN site.
Richard
Do you know Bunnery?
PostPosted: Sat Dec 13, 2014 9:48 pm
Because nothing says 'interoperability' more than a phase 1 vhf system linked to a phase 2 700 system, simulcast on a conventional channel using an IMBE vocoder.
BTW, both north and south are complaining of coverage issues...troopers stopping on the side of the road and having no coverage....
sigh...
PostPosted: Sun Dec 14, 2014 9:58 pm
Because nothing says interoperability more than multiband, multimode radios capable of roaming onto nearly any system in the state? Like WSP and WDFW using the Pierce County 7/800 system lately? Wide area trunking/roaming via the IWN system?
If wideband analog is best, please ditch your HDTV and go back to a 3-channel OTA set with rabbit ears (feel free to augment reception with coat hangers as needed).
FWIW, I too have noticed Troops complaining of dead zones, usually with the caveat that "signal is excellent on the portable, bad on car radio". Additionally, lots of busy bonks by users who have never had a PTT tone before (training issues).
PostPosted: Sun Dec 14, 2014 10:09 pm
Yep, I've heard the same complaints. I wonder if some of the car radios were not programmed correctly and/or have the wrong settings.
PostPosted: Sun Dec 14, 2014 11:06 pm
PostPosted: Sun Dec 14, 2014 11:08 pm
Digital does not like multipath. Multipath happens allot more when one uses high gain transmit antennas and lots of power. Especially on VHF. Said agency tends to use this combo.
PostPosted: Mon Dec 15, 2014 12:38 am
From what I understand, the APX mobiles were ordered in 50w versions,not 110w like the x9000 spectra orion m7100 and kenwoods before them.
PostPosted: Mon Dec 15, 2014 11:53 am
Im talking about the base station installs but yes you are correct about the 50 watt outputs on VHF of their new mobile radios.
PostPosted: Mon Dec 15, 2014 1:45 pm
If you are designing for 3 watt portable on the hip, you really can't expect a Tower Top Amp to have a dynamic range for a 110 Watt mobile with a gain antenna. Physics win every time....
PostPosted: Mon Dec 15, 2014 2:26 pm
The cops fought the law...and the law won..
lololol
PostPosted: Tue Dec 16, 2014 11:11 am
ok, updated my scanners today with the new P25 (not using the VHF channel). Using my PSR-500, so far they sound awful.
PostPosted: Tue Dec 16, 2014 2:40 pm
So what P25 system are you monitoring then..? The 700 or IWN?
PostPosted: Fri Dec 19, 2014 7:08 am
700, I had put in IWN but everything was annoyingly encrypted. Haven't had much time to listen yet, mostly I focus on the fire dept. :-)
PostPosted: Fri Dec 19, 2014 7:57 am
There are some things where wideband analog is best.
Public Safety LMR is one of them... The human ear is still a better decoder than any chip in the radio. Having a radio that wont at least attempt to break static is unacceptable to many of us. If the radio is making some kind of noise the user can at least adjust his position to try and listen. With digital they may never know their getting a call to try and adjust... In fringe areas or in heavy multipath where the signal is questionable.
Digital hides interference from the user. Analog users can report that they are hearing a beat tone/other users on system/ect.
PostPosted: Thu Dec 25, 2014 10:07 pm
Yup, in addition, the more complicated it is, the easier it is for someone to screw it up. There's always brute force, which works better the more complicated the system is. Jam a digital signal and you'd never know you're being jammed....just wouldn't have any audio...
Jam a single analog channel and someone switches to an alternate freq.
Jam a control channel and....watch the radios go into failsoft one by one....and hope it's analog, as site trunking won't work if it uses the control channel if it loses its link to the other zones.
I can't believe that so called security experts are so concerned about people being able to listen in and not cloning radios....but have a chain link fence and a gate with a dollar store padlock to secure critical infrastructure... This tells me that it's not about security ay all.
But that's for another thread....
/vent
