It is currently Thu Apr 30, 2026 8:36 pm
Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
 Post subject: Re: PSE going MPT-1327
PostPosted: Sat Nov 02, 2013 2:15 pm
Lots of activity today! Several voice frequencies are active in the 217 range. I think they're using 6.25khz steps... my 396XT wasn't picking up the voice in AUTO step mode. I had to manually put in 6.25khz steps for it to lock on...
PostPosted: Sat Nov 02, 2013 2:25 pm
Channels active from Bellevue:
217.70625
217.91875 (West dispatch?)
217.96875 (Central dispatch?)
Seems like the voice channels all use 146.2 PL
PostPosted: Sat Nov 02, 2013 3:54 pm
I heard these dispatch centers:
North-King
Central
West
Add South-King to this list.
PostPosted: Sat Nov 02, 2013 4:01 pm
PSE is using the old freq of 153.545 (114.8 ) in Whatcom Co. today so keep the old 153.xxx freqs in.
PostPosted: Sat Nov 02, 2013 4:15 pm
Must not be as sophisticated out there in Whatcom! :lol:
PostPosted: Sat Nov 02, 2013 4:31 pm
"2767 from South 2" heard on voice channels 217.5562 and 5062. They did give their road location. Previous VHF is completely silent down here.
PostPosted: Sat Nov 02, 2013 4:52 pm
They also use:
217.780 VOICE Input
217.8975 (110.9) VOICE Output
217.830 VOICE Input
217.9975 (110.9) VOICE Output
"North 2"
PostPosted: Sat Nov 02, 2013 5:00 pm
217.5062 is using 146.2 217.5562 shows 110.9
PostPosted: Sat Nov 02, 2013 7:14 pm
217.780 VOICE Input
217.830 VOICE Input
"North 2"
Jim, can you set your scanner to 6.25khz steps? It's hard to guess what frequency you're actually on...
I'm looking at my 396XT to find the strongest signal... that's how I'm verifying the actual frequency. With 6.25khz steps, there are usually two frequencies that sound the same... but their signal level will tell you which is the real output.
Thanks!
PostPosted: Sat Nov 02, 2013 7:53 pm
217.780 VOICE Input
217.830 VOICE Input
"North 2"
Thanks!
I was using a pro-97 so I don't know the exact freq but I can hear them clearly. I will have to try with a different scanner next time. Things have quieted down now and not as much traffic as when the wind was causing outages.
PostPosted: Sat Nov 02, 2013 11:25 pm
Sure -- no problem... it would be nice if the FCC would force them to make assigned frequencies but they don't have to it seems... they get total freedom apparently...
PostPosted: Mon Nov 04, 2013 8:13 pm
Code:
Puget Sound Energy MPT-1327 Site
Last updated:  11/4/2013
Stepping: 6.25 KHZ
BASE FREQUENCY:  217 Mhz
Voice Channels:
218.0875    * per TV         CH 174
217.98125   * Nick Verified  CH 157
217.96875   * Nick Verified  PL: 146.2
217.93125   * per TV         CH 149
217.91875   * Nick Verified  PL: 146.2
217.70625   * Nick Verified  PL: 146.2
217.45      * per TV         CH 072
217.50      * per TV         CH 080
Sites/Repeaters: (PL 110.9)
217.86875   ** constant data            51C9   **  (fairly strong in Bellevue)
217.84375   ** constant data            5119   **
217.81875   ** constant data            50B1   *** (strongest in Bellevue)
217.78125   ** constant data            50F1   **
217.76875   ** constant data            50D1   **
217.68125   ** constant data            51E9   **  (strong but need ext ant)
217.65625   ** constant data            51A9   **
217.64375   ** constant data            50B9   **
217.55625   ** constant data            5219   *   (really weak)
217.50625   ** constant data            51B9   **
Channel Assignments:
041 = 217.50625   = Site 51B9
048 = 217.        = Site 51D1
066 = 217.81875   = Site 50B1
068 = 217.84375   = Site 5119
069 = 217.        = Site 5191
070 = 217.86875   = Site 51C9
142 = 217.        = Site 51D1
150 = 217.        = Site 5231
151 = 217.        = Site 5199
153 = 217.65625   = Site 51A9
155 = 217.68125   = Site 51E9
156 = 217.        = Site 50F9
162 = 217.76875   = Site 50D1
164 = 217.        = Site 5259
165 = 217.        = Site 5239
173 = 217.        = Site 51B1
xxx = 217.64375   = Site 50B9
xxx = 217.78125   = Site 50F1
xxx = 217.55625   = Site 5219
Sites:
5081 = CH 067 = 217.
50B1 = CH 066 = 217.81875
50B9 = CH ### = 217.64375
50D1 = CH 162 = 217.76875
50D9 = CH ### = 217.
50F1 = CH ### = 217.78125
50F9 = CH ###
5119 = CH 068 = 217.84375
5121 = CH 041 = 217.
5191 = CH 069 = 217.
5199 = CH 151 = 217.
51A9 = CH 153 = 217.65625
51B1 = CH 173 = 217.
51B9 = CH 041 = 217.50625
51C1 = CH ### = 217.
51C9 = CH 070 = 217.86875
51D1 = CH 142 = 217.
51E9 = CH 155 = 217.68125
5219 = CH ### = 217.55625
5231 = CH 150 = 217.
5239 = CH 165 = 217.
5259 = CH 164 = 217.
Adjacents:
5081 ->
50B1 -> 5119, 51B9, 51C9, 51E9, 5239
50B9 -> 5081, 5121
50D1 -> 50B1, 51B9, 51C9, 51E9
50D9 ->
50F1 -> 50B1, 5119
50F9 ->
5119 -> 50B1, 50F9, 5199, 51A9, 51D1, 5231
5121 ->
5191 ->
5199 ->
51A9 -> 5119, 5191, 51B1, 51B9
51B1 ->
51B9 -> 50B1, 50D1, 5119, 5191, 51E9
51C1 ->
51C9 -> 50B1, 50D1, 5239
51D1 ->
51E9 -> 50B1, 5119, 5191, 51B9, 5259
5219 -> 5231, 5259
5231 ->
5239 ->
5259 ->
PostPosted: Mon Nov 04, 2013 8:14 pm
If you can get Trunkview working in your area then please help to fill in the missing SiteIDs/Frequencies, etc.
Be sure to set up the Site first using the information above.
PostPosted: Mon Nov 04, 2013 8:21 pm
So how do we come up with talkgroups?
PostPosted: Mon Nov 04, 2013 8:36 pm
Well there are no traditional talkgroups -- just channels. I believe the voice channels are not static -- meaning they rotate. They're not assigned to a specific city. They might be based on region though. It seemed like 217.70625 was more/less the Eastside. I just heard a new one tonight 217.98125 that sounded like Tacoma/Normandy Park area. I haven't confirmed this theory yet.
If you have a scanner with 6.25 steps, then just scan the 217-218 band for the repeater sites in your area. You can input the site audio to your computer's Line-In jack and Trunkview can give you the extraneous information.
The thing is for every site you can hit, you need to go to OPTIONS -> Enter Sites Database. Input the site information and then it'll calculate the info. Let it scan and you'll hear a BEEP through speaker when a voice channel is detected. It'll give you the frequency of the voice channel. Do this for all the sites you can monitor.
Example:
Control Channel: 217.81875 Mhz
Base frequency: 217.0 Mhz
Step: 6.25 khz
After several hits, you can hit F8 and it'll show you the statistics page and you can see how channels are linked, etc.
There's a 'control' function if you have a supported scanner model. I presume this is so the software can scan the sites and then monitor for voice activity. Then it can build a "complete" map of the system and voice channels.
Trunkview is here: http://www.linato.net/trunkview/
