It is currently Fri May 22, 2026 7:01 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jan 04, 2011 5:53 pm
According to one comment, this is the driver package:
http://www.moschip.com/mcs7703_downloads.php
That one didn't work for me, but I found another there and it worked! :P
Thanks for the help!!! :bowdown:
So now that I downloaded freescan and the above file...now what!? LOL How do I know what I'm listening to....should I have tiltles that tell me or do I just figure that out by listening over time??
"Better to have it and not need it then to need it and not have it"
PostPosted: Tue Jan 04, 2011 6:10 pm
BTW i did up upload the 346xt file to my scanner as well. Do I have to unlock what I want to listen to before I upload it to my scanner or after? Sorry I know I'm a PITA! :roll:
PostPosted: Tue Jan 04, 2011 7:17 pm
Are you able to connect to the scanner? Have you uploaded the programming from the file to the scanner via Freescan? If all is working well, the scanner will give a description of who you're listening to. I'm not sure what's in that file so I can't offer up any explanations as to what the various acronyms mean.
PostPosted: Tue Jan 04, 2011 7:32 pm
Yeah I did all that now I just need to figure out how to go directly to them.
PostPosted: Tue Jan 04, 2011 7:54 pm
Just upload Snohomish county and unlock everything. Here I did it for you, upload the attached file and tell FreeScan to erase everything else when you upload it.
snoco.996 [51.17 KiB]
Downloaded 72 times
PostPosted: Tue Jan 04, 2011 8:16 pm
Here, this is as simple as it gets.
SERS_West.996 [27.76 KiB]
Downloaded 91 times
Download the attached Freescan file. It contains JUST the SERS West system. Make sure to select the check box that says "Erase all systems and settings" in the upload dialog box.
Under system #1 I have 8 different groups programmed as follows:
1. SNOCOM Fire
2. SNOPAC Fire
3. Everett Fire
4. Snohomish County Sheriff
5. Everett Police
6. SNOCOM Police
7. Marysville Police
8. Miscellaneous
All 8 Groups are unlocked by default.
You can lock/unlock each group by holding the Function key and pressing the corresponding group number. For example, Fnc+4 would lock/unlock the Snohomish County Sheriff group. And within each Group there are Talk Groups which can be locked/unlocked individually also. If you thumb through the programming within Freescan you will see that I have certain Talk Groups locked out within a Group. For example, within the #4 SCSO Group I have all of the SCSO Talk Groups programmed but I only have SCSO South and the TAC Talk Groups unlocked. The other SCSO Talk Groups locked out because I don't care to listen to them all the time, BUT they are there in case I do decide I want to listen for one reason or the other.
PostPosted: Tue Jan 04, 2011 8:21 pm
Thanks Rich, So I did what you said and when I hit scan/search it says nothing to scan!?
PostPosted: Tue Jan 04, 2011 8:25 pm
Make sure you unlock what you want before you upload it to the scanner.
Also, if you want to only listen to one particular talkgroup, press HOLD while scanning and then rotate the knob until you've found the one you want.
PostPosted: Tue Jan 04, 2011 8:26 pm
Ok Rodentkj I give that a try.....then I'll read up on my scanner so I don't have to bug you guys so much! :lol:
Thanks AT!
PostPosted: Tue Jan 04, 2011 8:39 pm
Ok guys I think I got it now! You guys are great...I really appreciate you bearing with me and helping me out! I have what I want to listen to, and now it's time to do some reading and figure it all out! Which I probably should have done to start with!? :roll:
Rodentkj that worked great thanks for taking the time!
PostPosted: Tue Jan 04, 2011 9:19 pm
Great to see you have it up and running and able to connect to FreeScan. I'd install the full Rodentkj file that I linked up above. That file will get you the following systems loaded. Key numbers turn systems on/off. Your top side button (Func) turns groups on/off. You've no doubt figured that out.
1 Sno Co TRS West
2 Sno Co TRS East
3 King County Fire
4 King County PD
5 Seattle Simlcast
6 WA State Patrol
7 Boeing Trunk
8 CB FRS GMRS
Depending on where you live in Everett you should be able to hear the Seattle systems. I don't have any problem with a RS 800 mhz antenna from 7 miles N. of Monroe. Have fun!..... :D
PostPosted: Wed Jan 05, 2011 3:57 pm
Cool thanks K7CAR!
PostPosted: Wed Jan 05, 2011 5:13 pm
I'm redoing my whole scanner file so the TG's are better labeled. If you want to know when I'm done with it let me know.
-Daron
PostPosted: Wed Jan 05, 2011 5:24 pm
-Daron
I just added the current one,but yeah let me know!
PostPosted: Mon Jan 24, 2011 4:03 pm
Thanks for all your help guys but my scanner is now for sell.....I just don't have the time or patience for this scanner. :? Plus It's just easier for me to listen to daron's feed when I'm at work. Check out my listing in the classifieds section! http://www.interceptradio.com/bbs/viewtopic.php?f=4&t=5066
