It is currently Mon May 25, 2026 3:12 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 454.41875 ?
PostPosted: Mon Sep 21, 2009 11:12 pm
KE7JFF wrote:
Passport also adds radio ID support via an ESN so you can authorize radios on the system, correct?
And block radios that you don't want on the system.
PostPosted: Tue Sep 22, 2009 6:00 am
Passport uses 3 ID's
ESN, MIN, TGID
ESN is embedded in the radio, and is used on power up to authorize the radio into the system. ESN authorization is an option, and not required. As I recall the ESN authorization is selected at a group level and not radio. (It's been a while)
MIN is Mobile ID Number. MIN is programmed into the radio and becomes the individual ID for the radio. MIN is what is used for select calling and ANI.
TGID is like any other system, Talk Group ID. Functionality is basically the same as any other trunk system.
One item to note on Passport TGIDs is, all customers have 1 "Primary" TGID along with however many standard TGIDs are assigned to the customer. The Primary TGID is similar to a Moneyrola ATG. If a user TX on Primary TG, then all TG's in the customer will receive. Basically an "All Call" for the customer.
PostPosted: Mon Sep 28, 2009 10:23 am
So are there other, related frequencies to this one we could add in if we wanted to monitor these guys? Not that they say much interesting....
PostPosted: Mon Sep 28, 2009 11:22 am
LTR-Analyzer should be able to decode the LCN's of a narrowband passport system. Might be a good way to find some related frequencies.
PostPosted: Tue Sep 29, 2009 11:20 pm
At one time I had some notes on a few of these, but I have no idea what happened to the notes. It's pretty easy to tell which ones are using LTR just by listening.
451.2375
451.3125
451.3375
451.4000
451.4125
451.4625
451.4750
451.5125
451.5625
451.6000
451.6125
451.6375
451.6625
451.6750
451.7000
451.9500
452.1125
452.1375
452.1625
452.4000
452.4125
456.2375
456.3125
456.3375
456.4125
456.4625
456.4750
456.5125
456.5625
456.6000
456.6125
456.6375
456.6625
456.6750
456.7000
456.9500
457.1125
457.1375
457.1625
457.2875
457.4125
461.6375
461.6500
461.6875
461.9125
462.4500
462.5000
463.3375
463.5375
464.8125
