It is currently Sat May 23, 2026 7:48 am
Post new topic Reply to topic  [ 447 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 30  Next
 Post subject: Re: WSP Radio Upgrade
PostPosted: Thu Aug 15, 2013 7:45 am
This is about 1.5 years old...
http://www.dailywireless.org/2012/03/28 ... -of-money/
PostPosted: Wed Oct 02, 2013 2:15 pm
I'm hearing a solid tone (for several hours now) on the "WSP Academy" frequency with the default NAC of 293.
Thurston County, WA
PostPosted: Wed Oct 02, 2013 3:58 pm
They're doing some coverage tests.
PostPosted: Thu Oct 03, 2013 10:02 am
Was going for days in the Kitsap area.
PostPosted: Thu Oct 03, 2013 9:10 pm
Was it the 1011 Hz pattern?
Might be coverage mapping.
PostPosted: Fri Oct 04, 2013 8:25 am
PostPosted: Fri Oct 04, 2013 8:41 am
For us ignat's, that mean there is a truck driving around taking receive readings to find the P25 dead spots?
PostPosted: Fri Oct 04, 2013 8:49 am
Yea- something like that. :wink:
PostPosted: Fri Oct 04, 2013 9:25 am
...and the P25 dead spots will be That much different than the analog?
PostPosted: Fri Oct 04, 2013 10:12 am
While I can't say for certain that the 1011 pattern is the best or most common or anything like that.
It is one of the methods used for coverage mapping.
TX the 1011hz pattern, set up your Anritsu S412E for a map of the area you are going to check, settings for 1011 bit error rate coverage mapping, and as you drive around it takes thousands of readings and plots them on the map.
And yes, the P25 coverage will be different (lets say) than analog.
There are other coverage measuring "schemes", but this is the one I use.
Sounds very much like someone doing the 1000 cycle tone SINAD test on analog.
Do "before" with SINAD, then P25 BER test and compare the coverage.
PostPosted: Tue Oct 08, 2013 10:22 am
Tone is up on Car-4 now, analog CSQ.
PostPosted: Tue Oct 08, 2013 8:14 pm
Yea- everytime I get in my vehicle I have to hit the scan delete button.
PostPosted: Tue Oct 08, 2013 8:22 pm
I turned on the radio and thought, in quick succession:
-Damn that's annoying...
-Sgt is probably getting madder by the second...
-Wait, who's using Car-4?
-Waaaaaaiiiittttt, who has a DTMF mic???
-Fricking techs. I wonder if there's a way to blame Sean?
PostPosted: Tue Oct 08, 2013 9:47 pm
My wife will find a way.
PostPosted: Wed Oct 09, 2013 5:32 am
It's not just her...
Users browsing this forum: No registered users and 38 guests
