It is currently Thu May 28, 2026 7:02 am
Post new topic Reply to topic  [ 447 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 30  Next
 Post subject: Re: WSP Radio Upgrade
PostPosted: Tue Jan 15, 2013 3:45 pm
Currently listening to WSP in P25.
PostPosted: Tue Jan 15, 2013 8:11 pm
Yeah mine sounds like they are in a can. And I get a little here and a little there, but nothing major. I have mine set to the D30 NAC, then another one set on NAC scan on the 154.920 frequency.
PostPosted: Wed Jan 16, 2013 12:36 am
I think I will setup the Astro Spectra to do mixed mode on the Vancouver frequencies just in case.
PostPosted: Wed Jan 16, 2013 9:55 am
I'd be curious to see if the NAC "plan" that has been described is actually seen to exist. (i.e. DX0 where x is the district #)
PostPosted: Wed Jan 16, 2013 12:16 pm
That would be interesting to see. I have't heard anything on the digital today, and the analog is still just noise.
PostPosted: Wed Jan 16, 2013 5:25 pm
We've been listening to it all day and it's remarkably clear in Moses Lake. The noise you're hearing is probably the P25 traffic. Run the channel in NAC search mode.
PostPosted: Wed Jan 16, 2013 6:50 pm
I heard Yakima over on this side too.
Yes, there is a large reflector over here
PostPosted: Wed Jan 16, 2013 7:58 pm
I have 2 channels programmed. One is on the NAC search, and the other is on NAC D30. Still nothing much on mine. Probably the scanner itself I mean it is a homopatrol scanner...lol
I moved it over by a window and it is a little better, still doesnt sound good. Sounds all warbled, and not like the old analog used to sound. This sounds like CRAP.
PostPosted: Wed Jan 16, 2013 8:31 pm
Oh you're trying to do this with one of those piles!? Why didn't you say so! LMAO!
Do you have the firmware/version that allows for direct entry or are you relying on the horribly inaccurate and outdated RR DB?
PostPosted: Wed Jan 16, 2013 8:51 pm
My APX has the latest firmware version....
PostPosted: Wed Jan 16, 2013 9:21 pm
So far, Vancouver has been in analog in my listening.
PostPosted: Wed Jan 16, 2013 9:41 pm
Which APX?
-the guy that doesn't have any multi-band radios
PostPosted: Wed Jan 16, 2013 11:44 pm
Yeah same for Seattle. I've got my PSR800 set up for capturing any digital traffic on P25 for 155.58 -- so if those techs try to be sneaky and transmit at 3am... I should capture it. ;)
PostPosted: Thu Jan 17, 2013 9:29 am
They played with it during the day on the digital side before they made the change. I was hearing the noise on the analog side. So you should know when they are playing with it.
PostPosted: Thu Jan 17, 2013 9:32 am
I use the computer program which is sentinal. I can do manual entry. But I went through and did them manually since RR doesn't update thier DB. So I set one search for the NAC code, and the second to NSC D30. Now that it is by the window it sounds better, but it sucks that I have to have it on the other side of the room to listen to it..
