It is currently Mon May 04, 2026 4:18 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 03, 2016 7:40 am
You can also upload a copy of your FreeSCAN file and one of the trunking/rebanding experts can critique it.
That would be great if someone could take a peek at my file. Its pretty small.
All I care about is Kirkland PD. I may add the Fire Dept at some point.
Also picking up Close Call conversations.
The file is here -
https://www.dropbox.com/s/6y3a0wncicr4o ... 2.996?dl=0
PostPosted: Thu Mar 03, 2016 4:01 pm
I'll upload my 996 file later tonight I promise. I just got really busy with work this week and my radio stuff is on my other laptop.
Hey you're definitely missing the rebanding which is necessary but also you have your talkgroups all checked with PRI enabled. Uncheck ALL of those... that's why you were missing some conversations as well. You can uncheck REC OUT that doesn't mean anything in this case.
Tip: Rename your group name to "Kirkland PD" and then you can get rid of "police" in each of the talkgroup names...
For each site, under "Site Type" change to "Motorola Custom/Reband Type II" and input those two lines I showed you from that URL.
BTW, at the very top level under the MOT2 folder, your ID mode is under "ID SCAN" which is fine but you'll ONLY hear those TGIDs that you have in your group. If you change to "ID SEARCH" then you'll hear everything on the system.
All in all, not bad for a first attempt. Good job.
PostPosted: Thu Mar 03, 2016 6:44 pm
Here's my latest Uniden file: https://www.dropbox.com/s/ndu3cpovxjzs7 ... .996?raw=1
Here's what the rebanding section should look like: https://www.dropbox.com/s/wispnrvy19jjd ... .jpg?raw=1
(Sorry this is from Uniden Sentinel but it should look similar.)
PostPosted: Thu Mar 03, 2016 7:00 pm
Great thanks. I made the changes as suggested.
In regards to Scan vs Search when it is set to Search there is traffic from all over the place.
I swear I heard Auburn once.
If its set to Scan then its only the Kirkland as far as I can tell.
PostPosted: Thu Mar 03, 2016 7:14 pm
Hov wrote:
Great thanks. I made the changes as suggested. In regards to Scan vs Search when it is set to Search there is traffic from all over the place. I swear I heard Auburn once. If its set to Scan then its only the Kirkland as far as I can tell.
Right you'll just hear whatever talkgroups you've programmed in...
