It is currently Fri May 15, 2026 3:01 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rebanding ?
PostPosted: Thu May 27, 2010 5:09 pm
SpudGunMan wrote:
?? I thought this was already done.. I just replaced my last analog TV with a HD tuner TV and got my new digital antenna up. it took about 20 min. Didnt you get the goverment rebate for this project?
700 MHz != 800 MHz rebanding
PostPosted: Fri May 28, 2010 8:02 am
haha yea I was just being a smart ass
PostPosted: Fri May 28, 2010 8:05 am
Oh, I had the smiley on Adblock. Makes more sense now.
PostPosted: Fri Jun 04, 2010 12:30 pm
My understanding from a Sound Transit source says they expect to be done with re-banding possibly by the 12 of June 2010. If and when I get the Freq, I will post them. I believe the trunking talk groups will be the same? If anyone else has any info, please post for "Link Light Rail"
Thanks
N7ENE
PostPosted: Fri Jun 04, 2010 10:51 pm
Thanks
N7ENE
Wrong. The FRA may be done by then. Figure at least 2 years and more like 3.
PostPosted: Sat Jun 19, 2010 5:16 pm
So if you have a BC246 and you have rebanded the radio already.
When this whole process of rebanding is complete will my BC 246 radio still work the way it does now and receives all of King County Police and fire.
PostPosted: Mon Jun 21, 2010 12:00 am
Probably not, because they're going to go with a shuffled band plan. I don't think the hard key will make much of a difference though.
PostPosted: Mon Jun 21, 2010 3:09 am
So I take it the days of people monitoring King County Police and fire are limited.
PostPosted: Mon Jun 21, 2010 6:00 am
As long as the receive frequency is predictable it shouldn't change the ability to listen, right?
PostPosted: Mon Jun 21, 2010 11:50 am
It will require a combination of:
Firmware from your scanner-of-choice vendor that supports shuffled bandplan
Knowledge of Freq vs. DFA Mapping (or whatever its called in MotoSpeak)
Until then, we are busted back to the dark ages, monitoring raw trunks at best.
I predict a scanner logging app will allow us to map the freqs before a firmware becomes available.
I will wager 6 MX channel elements on this prediction.
Any takers?
PostPosted: Mon Jun 21, 2010 12:04 pm
The frequencies will be predictable, yes, but determining which frequency is assigned which channel number will require some work. And who knows how often the system managers will "renumber" the channels. They'll be able to reprogram radios over the air.
PostPosted: Mon Jun 21, 2010 12:07 pm
:bowrofl:
PostPosted: Mon Jun 21, 2010 7:36 pm
Well, this will suck. May have to talk the department out of a real portable when that happens....
