It is currently Tue May 19, 2026 10:29 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Monitoring PSE
PostPosted: Wed Jul 29, 2009 5:10 pm
loud and clear where? i havent heard them use the "system" to any real degree in the last two storms.
PostPosted: Wed Jul 29, 2009 7:41 pm
153.440 (103.5) dispatching here in Puyallup (the office is like 3 blocks from my place)
153.410 (103.5) PSE chatting in Pierce Co area (infrequently)
PostPosted: Thu Jul 30, 2009 8:28 am
PSE Kirk/Redmond 153.605000 FM CTCSS 103.5 0
PSE Bellevue 153.650000 FM CTCSS 103.5 0
Both have been working fine for me.
PostPosted: Thu Jul 30, 2009 8:44 am
I see scattered references to Puget Power in the database and the the PSE page only has the 900MHz system. Is there an all-inclusive PSE page I'm missing somewhere?
PostPosted: Thu Jul 30, 2009 9:02 am
I lost power at the home yesterday afternoon and turned on the PSE bank to listen in. I had both gas and electric traffic. Gas was on the Seattle EDACS site.
PostPosted: Thu Jul 30, 2009 10:10 am
PSE has a ton of VHF frequencies. The EDACS system is only used by the gas guys. Try this DB search.
PostPosted: Thu Jul 30, 2009 10:13 am
So for power I should listen to the local VHF channel or is there a main dispatch and a local work channel?
PostPosted: Thu Jul 30, 2009 10:54 am
PSE uses:
153.545 (114.8) WHATCOM/THURSTON
153.620 (114.8) SKAGIT/N. BEND
153.410 (103.5) ON SCENE SIMPLEX
153.425 (103.5) WHIDBEY IS.
153.605 (103.5) KIRKLAND/REDMOND
153.635 (103.5) PORT TOWN/VASHON IS.
ALSO Kitsap County
153.650 (103.5) BELLEVUE/FACTORIA
153.680 (103.5) AUBURN/S. KING CO.
158.130 (103.5) KITSAP CO.
158.145 (103.5) RENTON
153.440 (103.5) PUYALLUP
I hear them all the time here on 153.545 (114.8)
PostPosted: Thu Jul 30, 2009 12:52 pm
my building has blown transformers 2 days in a row, i never see any VHF on the trucks in front of me only 900 looking antennas. I only get full static on the bellevue disp right now, but Im also too hot to figure it out.
PostPosted: Thu Jul 30, 2009 1:27 pm
So for those with the gas stuff working, did you specify EDACS or EDACS narrow?
PostPosted: Thu Jul 30, 2009 1:45 pm
If your building has blown transformers 2 days in a row it is probably better you can't hear what they are saying :bowrofl: @#$%&^!!!
PostPosted: Thu Jul 30, 2009 3:18 pm
Narrow 4800.
I have Seattle set up for
01-935.4500
02-935.4625
03-935.4750
04-935.4875
05-935.5000
and Tiger Mtn
01-936.4375
02-936.4500
03-936.4625
04-936.0000
It has always been a quiet system for gas dispatch only.
PostPosted: Fri Jul 31, 2009 9:29 am
My PSR500 doesn't have the baud rate exposed, so I selected EDACs Narrow. I have all the freqs for all repeater sites in as system frequencies - will that mess up an EDACs system? Also I have a setting for EDACS-N: Invert Data. No clue what that does - should it be selected?
PostPosted: Fri Jul 31, 2009 1:02 pm
I have limited experience with EDACS. If UniTrunker says narrow I just set narrow. FWIW - UniTrunker options say the data is inverted on this system. Just insure that you have the frequencies matched properly to the LCNs.
PostPosted: Sun Oct 25, 2009 3:56 pm
PSE Gas EDACS SID-01 for Capitol Pk
1 - 938.3875
3 - 938.4125
4 - 938.4375
Database updates will follow when I can get in.
Users browsing this forum: No registered users and 35 guests
