It is currently Wed Sep 09, 2026 8:59 am
 Post subject: New Orleans federal logs
PostPosted: Sat Jul 25, 2026 8:01 am
164.225 ($102) Strategic Petroleum Reserve NOLA (enc)
168.4875 (146.2) VA Hospital NOLA Patient Guides
172.300 (179.9) VA Hospital NOLA unknown
173.175 ($293) VA Hospital NOLA- security, not police?
162.050 ($293) CG-108
162.125 ($293) CG-109
163.050 ($293) CG-112
163.1125 ($169) ICE SURVEILLANCE
163.5375 ($100) CBP?
163.700 ($169) ICE SURVEILLANCE
163.9625 ($167) FBI NOLA RIDS 336XXXX
165.4125 ($301) CBP 522XXXX/523XXXX
165.725 ($293) ENC, 824XXXX INPUT TO USMS COURTHOUSE SECURITY 170.750 NOLA
166.350 ($167) FBI NOLA RIDS 336XXXX
166.3875 ($167) FBI NOLA RIDS 336XXXX
167.4375 ($167) FBI NOLA RIDS 336XXXX
168.450 ($102) STRATEGIC PETROLEUM RESERVE NOLA
168.5875 ($169) ICE SURVEILLANCE
169.450 ($301) ICE DTAC-2 ENC
170.750 ($293) USMS COURTHOUSE SECURITY NOLA
171.0125 ($293) VA NOLA ENGINEERING?
171.4625 ($167) FBI NOLA RIDS 336XXXX
171.6125 ($167) FBI NOLA RIDS 336XXXX
171.6625 ($C00) 515XXXX CBP
172.325 ($167) FBI NOLA RIDS 336XXXX
173.0125 ($650) BATFE TAC-3
173.175 ($293)- VA HOSPITAL POLICE NOLA KLM500
173.700 ($004) 522XXXX
409.9375 ($482) USPIS BLACK CH
410.5875 ($742) FPS RIDS 675XXXX
410.700 ($742) FPS RIDS 675XXXX
411.7875 ($293) CG-402
406.6625 ($110) Federal Reserve Bank ATL, NOLA branch police dispatch
Two ships in NOLA (among many others) for Fleet Week:
System ID : AD4
System Name : USS Kearsarge (LHD-3) $AD1
WACN : 00000
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description : 001 $AD1
Control Capabilities : Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat May 30 10:12:25 2026
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,380.00000,0.02500,0.90000,"Assumed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-1125","v",408.12500,"00-1125",409.02500,0,0
"00-1148","c",408.70000,"00-1492",417.30000,1,0
Also noted was 407.075 but Pro96Com was having fits with this system being in site trunking.
TG-1 only enc
TG-2 operations: Officer of the Deck, Safety, Tour Guides, etc.
USS Farragut (DDG-99) has an EDACS Hydra system on board. I did not dick around with it but noted the control channel on 397.3500 showing a site of 5.
One of the other vessels, I suspect the USCGC Mohawk, though the Eagle could be considered, was using 410.375 (67.0) for operations...mostly dealing with the massive crowds coming on board for tours.
PostPosted: Sun Aug 02, 2026 12:32 pm
System ID : AD4
WACN : 00000
Flavor : Phase 1
Call Sign(s) :
-Tables
-Frequencies
TG-1 only enc
Interesting to see the Kearsarge upgraded from
USS Kearsarge LHD-3, Sys 740E S-001 CT 128.57
And that the Farragut moved from USS Farragut DDG-99, Trunked System Sys C22A to EDACs
and 410.3750 67.0 is the Barque Eagle, they moved away from the old 450/455 Media Channels
