It is currently Mon Aug 24, 2026 10:02 am
 Post subject: Keesler AFB, MS
PostPosted: Sat Aug 22, 2020 1:15 pm
Keesler AFB Pro96Com logs below. Totally encrypted.
System ID : 3D6
System Name : USAF
WACN : BEE00
Tower Number (Decimal): 1-20
Tower Number (Hex) : T0114
Tower Description : KEESLER AFB MS
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Aug 13 08:09:57 2020
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.00625,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,382.93750,0.01250,9.00000,"Confirmed",0.01250,1
05,380.00000,0.01250,10.00000,"Confirmed",0.01250,1
06,136.00000,0.01250,5.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"05-0428","c",385.35000,"05-0428",395.35000,0,0
"05-0471","vd",385.88750,"05-0471",395.88750,0,1
"05-0496","a",386.20000,"05-0496",396.20000,0,0
"05-0524","vd",386.55000,"05-0524",396.55000,0,1
"05-0540","a",386.75000,"05-0540",396.75000,0,0
"05-0557","vd",386.96250,"05-0557",396.96250,0,1
"05-0660","a",388.25000,"05-0660",398.25000,0,0
"05-0685","vd",388.56250,"05-0685",0.00000,0,0
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits,EmrgIgnore
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
4811,50,"T: 120 DT: 8/13/20@8:04",1597331396,"08/13/2020 @ 08:09",1597331083,"08/13/2020 @ 08:04","#000000","#000000","Y",2,1
4822,50,"T: 120 DT: 8/13/20@8:06",1597331317,"08/13/2020 @ 08:08",1597331186,"08/13/2020 @ 08:06","#000000","#000000","Y",3,1
4824,50,"T: 120 DT: 8/13/20@8:08",1597331298,"08/13/2020 @ 08:08",1597331291,"08/13/2020 @ 08:08","#000000","#000000","Y",1,1
4835,50,"T: 120 DT: 8/13/20@8:05",1597331148,"08/13/2020 @ 08:05",1597331136,"08/13/2020 @ 08:05","#000000","#000000","Y",4,1
4855,50,"T: 120 DT: 8/13/20@8:04",1597331086,"08/13/2020 @ 08:04",1597331086,"08/13/2020 @ 08:04","#000000","#000000","N",0,1
4866,50,"T: 120 DT: 8/13/20@8:05",1597331160,"08/13/2020 @ 08:06",1597331147,"08/13/2020 @ 08:05","#000000","#000000","Y",2,1
4888,50,"T: 120 DT: 8/13/20@8:04",1597331389,"08/13/2020 @ 08:09",1597331045,"08/13/2020 @ 08:04","#000000","#000000","Y",10,1
4900,50,"T: 120 DT: 8/13/20@8:07",1597331271,"08/13/2020 @ 08:07",1597331262,"08/13/2020 @ 08:07","#000000","#000000","Y",1,1
 Post subject: Re: Keesler AFB, MS
PostPosted: Wed Jul 28, 2021 5:41 pm
Small update; still 100% encrypted.
System ID : 3D6
System Name : USAF
WACN : BEE00
Flavor : Phase 2
Call Sign(s) :
Timestamp : Wed Jul 28 20:38:44 2021
-Frequencies
"05-0471","vd",385.88750,"05-0471",395.88750,0,128
"05-0524","vd",386.55000,"05-0524",396.55000,0,109
"05-0540","av",386.75000,"05-0540",396.75000,0,0
"05-0557","vd",386.96250,"05-0557",396.96250,0,106
"05-0660","ad",388.25000,"05-0660",398.25000,0,0
"05-0685","vd",388.56250,"05-0685",398.56250,0,110
4800,50,"T: 120 DT: 7/28/21@17:31",1627511487,"07/28/2021 @ 17:31",1627511482,"07/28/2021 @ 17:31","#000000","#000000","Y",1,1
4811,50,"T: 120 DT: 8/13/20@8:04",1627512527,"07/28/2021 @ 17:48",1597331083,"08/13/2020 @ 10:04","#000000","#000000","Y",289,1
4812,50,"T: 120 DT: 7/5/21@22:46",1625543212,"07/05/2021 @ 22:46",1625543212,"07/05/2021 @ 22:46","#000000","#000000","N",0,1
4813,50,"T: 120 DT: 7/6/21@6:24",1625570640,"07/06/2021 @ 06:24",1625570640,"07/06/2021 @ 06:24","#000000","#000000","N",0,1
4814,50,"T: 120 DT: 7/6/21@5:55",1625568942,"07/06/2021 @ 05:55",1625568942,"07/06/2021 @ 05:55","#000000","#000000","N",0,1
4822,50,"T: 120 DT: 8/13/20@8:06",1627522671,"07/28/2021 @ 20:37",1597331186,"08/13/2020 @ 10:06","#000000","#000000","Y",609,1
4823,50,"T: 120 DT: 5/4/21@15:47",1627521696,"07/28/2021 @ 20:21",1620161264,"05/04/2021 @ 15:47","#000000","#000000","Y",179,1
4824,50,"T: 120 DT: 8/13/20@8:08",1625577800,"07/06/2021 @ 08:23",1597331291,"08/13/2020 @ 10:08","#000000","#000000","Y",37,1
4833,50,"T: 120 DT: 7/5/21@22:46",1625543210,"07/05/2021 @ 22:46",1625543210,"07/05/2021 @ 22:46","#000000","#000000","N",0,1
4835,50,"T: 120 DT: 8/13/20@8:05",1597331148,"08/13/2020 @ 10:05",1597331136,"08/13/2020 @ 10:05","#000000","#000000","Y",4,1
4838,50,"T: 120 DT: 7/6/21@5:54",1625568886,"07/06/2021 @ 05:54",1625568886,"07/06/2021 @ 05:54","#000000","#000000","N",0,1
4845,50,"T: 120 DT: 7/28/21@19:30",1627518638,"07/28/2021 @ 19:30",1627518638,"07/28/2021 @ 19:30","#000000","#000000","N",0,1
4855,50,"T: 120 DT: 8/13/20@8:04",1625578079,"07/06/2021 @ 08:27",1597331086,"08/13/2020 @ 10:04","#000000","#000000","Y",121,1
4862,50,"T: 120 DT: 7/6/21@7:05",1625573156,"07/06/2021 @ 07:05",1625573156,"07/06/2021 @ 07:05","#000000","#000000","N",0,1
4866,50,"T: 120 DT: 8/13/20@8:05",1627510850,"07/28/2021 @ 17:20",1597331147,"08/13/2020 @ 10:05","#000000","#000000","Y",745,1
4868,50,"T: 120 DT: 6/4/21@12:19",1627520998,"07/28/2021 @ 20:09",1622827159,"06/04/2021 @ 12:19","#000000","#000000","Y",26,1
4877,50,"T: 120 DT: 6/15/21@17:57",1623797843,"06/15/2021 @ 17:57",1623797843,"06/15/2021 @ 17:57","#000000","#000000","N",0,1
4880,50,"T: 120 DT: 7/5/21@22:44",1625543089,"07/05/2021 @ 22:44",1625543089,"07/05/2021 @ 22:44","#000000","#000000","N",0,1
4888,50,"T: 120 DT: 8/13/20@8:04",1627519369,"07/28/2021 @ 19:42",1597331045,"08/13/2020 @ 10:04","#000000","#000000","Y",63,1
4892,50,"T: 120 DT: 6/15/21@15:05",1623787525,"06/15/2021 @ 15:05",1623787525,"06/15/2021 @ 15:05","#000000","#000000","N",0,1
4893,50,"T: 120 DT: 6/15/21@15:06",1623787581,"06/15/2021 @ 15:06",1623787581,"06/15/2021 @ 15:06","#000000","#000000","N",0,1
4900,50,"T: 120 DT: 8/13/20@8:07",1627521403,"07/28/2021 @ 20:16",1597331262,"08/13/2020 @ 10:07","#000000","#000000","Y",313,1
4901,50,"T: 120 DT: 7/6/21@6:35",1625571352,"07/06/2021 @ 06:35",1625571352,"07/06/2021 @ 06:35","#000000","#000000","N",0,1
4902,50,"T: 120 DT: 6/15/21@14:39",1623785942,"06/15/2021 @ 14:39",1623785942,"06/15/2021 @ 14:39","#000000","#000000","N",0,1
4904,50,"T: 120 DT: 6/15/21@14:34",1623785650,"06/15/2021 @ 14:34",1623785650,"06/15/2021 @ 14:34","#000000","#000000","N",0,1
4911,50,"T: 120 DT: 7/28/21@16:26",1627507582,"07/28/2021 @ 16:26",1627507582,"07/28/2021 @ 16:26","#000000","#000000","N",0,1
4916,50,"T: 120 DT: 5/4/21@15:48",1620161301,"05/04/2021 @ 15:48",1620161301,"05/04/2021 @ 15:48","#000000","#000000","N",0,1
PostPosted: Fri Oct 07, 2022 1:05 am
Just revisiting this system; still 100% encrypted.
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 3D6
System Name : USAF
WACN : BEE00
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Oct 6 07:56:39 2022
-Frequencies
"05-0471","vd",385.88750,"05-0471",395.88750,0,56
"05-0524","vd",386.55000,"05-0524",396.55000,0,64
"05-0557","vd",386.96250,"05-0557",396.96250,0,49
"05-0685","vd",388.56250,"05-0685",398.56250,0,76
4811,50,"FIRE-1",1665060930,"10/06/2022 @ 07:55",1597331083,"08/13/2020 @ 10:04","#000000","#000000","Y",404,1
4812,50,"FIRE TAC-2",1664757832,"10/02/2022 @ 19:43",1625543212,"07/05/2021 @ 22:46","#000000","#000000","N",0,1
4822,50,"POLICE DISPATCH",1665060712,"10/06/2022 @ 07:51",1597331186,"08/13/2020 @ 10:06","#000000","#000000","Y",1165,1
4823,50,"POLICE TAC-2",1665055801,"10/06/2022 @ 06:30",1620161264,"05/04/2021 @ 15:47","#000000","#000000","Y",380,1
4824,50,"POLICE TAC-3",1664757714,"10/02/2022 @ 19:41",1597331291,"08/13/2020 @ 10:08","#000000","#000000","Y",38,1
4825,50,"POLICE TAC-4",1664757772,"10/02/2022 @ 19:42",1664728445,"10/02/2022 @ 11:34","#000000","#000000","N",0,1
4833,50,"81ST MED GROUP-1",1664757815,"10/02/2022 @ 19:43",1625543210,"07/05/2021 @ 22:46","#000000","#000000","N",0,1
4847,50,"T: 120 DT: 10/6/22@6:10",1665054622,"10/06/2022 @ 06:10",1665054622,"10/06/2022 @ 06:10","#000000","#000000","N",0,1
4855,50,"PUB WORKS-1",1665060970,"10/06/2022 @ 07:56",1597331086,"08/13/2020 @ 10:04","#000000","#000000","Y",126,1
4856,50,"T: 120 DT: 10/6/22@7:20",1665058852,"10/06/2022 @ 07:20",1665058852,"10/06/2022 @ 07:20","#000000","#000000","N",0,1
4861,50,"T: 120 DT: 8/5/22@19:19",1659745156,"08/05/2022 @ 19:19",1659745156,"08/05/2022 @ 19:19","#000000","#000000","N",0,1
4866,50,"TRANSPORTATION-1",1665060902,"10/06/2022 @ 07:55",1597331147,"08/13/2020 @ 10:05","#000000","#000000","Y",772,1
4868,50,"POL NET",1665060991,"10/06/2022 @ 07:56",1622827159,"06/04/2021 @ 12:19","#000000","#000000","Y",32,1
4888,50,"403RD RAMP NET",1665060860,"10/06/2022 @ 07:54",1597331045,"08/13/2020 @ 10:04","#000000","#000000","Y",97,1
4900,50,"403RD MOC-1",1665060972,"10/06/2022 @ 07:56",1597331262,"08/13/2020 @ 10:07","#000000","#000000","Y",464,1
PostPosted: Sun Apr 06, 2025 11:14 am
A few years gone by and only a few new talkgroups added. Still unmonitorable.
System ID : 3D6
System Name : USAF
WACN : BEE00
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sun Apr 6 14:08:53 2025
-Frequencies
"05-0471","vd",385.88750,"05-0471",395.88750,0,81
"05-0524","vd",386.55000,"05-0524",396.55000,0,94
"05-0557","vd",386.96250,"05-0557",396.96250,0,85
"05-0685","vd",388.56250,"05-0685",398.56250,0,81
4804,50,"T: 120 DT: 4/29/23@16:38",1682804329,"04/29/2023 @ 16:38",1682804329,"04/29/2023 @ 16:38","#000000","#000000","N",0,1
4806,50,"T: 120 DT: 4/29/23@16:15",1682802950,"04/29/2023 @ 16:15",1682802950,"04/29/2023 @ 16:15","#000000","#000000","N",0,1
4811,50,"FIRE-1",1743964865,"04/06/2025 @ 13:41",1597331083,"08/13/2020 @ 10:04","#000000","#000000","Y",551,1
4822,50,"POLICE DISPATCH",1743966430,"04/06/2025 @ 14:07",1597331186,"08/13/2020 @ 10:06","#000000","#000000","Y",1466,1
4823,50,"POLICE TAC-2",1743965721,"04/06/2025 @ 13:55",1620161264,"05/04/2021 @ 15:47","#000000","#000000","Y",545,1
4824,50,"POLICE TAC-3",1682813683,"04/29/2023 @ 19:14",1597331291,"08/13/2020 @ 10:08","#000000","#000000","Y",40,1
4833,50,"81ST MED GROUP-1",1682800556,"04/29/2023 @ 15:35",1625543210,"07/05/2021 @ 22:46","#000000","#000000","Y",1,1
4834,50,"81st MED GROUP-2",1682801977,"04/29/2023 @ 15:59",1682800628,"04/29/2023 @ 15:37","#000000","#000000","Y",9,1
4836,50,"T: 120 DT: 4/29/23@15:48",1682801798,"04/29/2023 @ 15:56",1682801329,"04/29/2023 @ 15:48","#000000","#000000","Y",2,1
4837,50,"MEDICAL?",1707346190,"02/07/2024 @ 16:49",1707332885,"02/07/2024 @ 13:08","#000000","#000000","N",0,1
4838,50,"MEDICAL?",1707346200,"02/07/2024 @ 16:50",1625568886,"07/06/2021 @ 05:54","#000000","#000000","N",0,1
4855,50,"PUB WORKS-1",1743955804,"04/06/2025 @ 11:10",1597331086,"08/13/2020 @ 10:04","#000000","#000000","Y",271,1
4858,50,"T: 120 DT: 4/29/23@15:42",1682800932,"04/29/2023 @ 15:42",1682800932,"04/29/2023 @ 15:42","#000000","#000000","N",0,1
4860,50,"T: 120 DT: 2/7/24@14:57",1707339422,"02/07/2024 @ 14:57",1707339422,"02/07/2024 @ 14:57","#000000","#000000","N",0,1
4866,50,"TRANSPORTATION-1",1707340969,"02/07/2024 @ 15:22",1597331147,"08/13/2020 @ 10:05","#000000","#000000","Y",934,1
4867,50,"TRANSPORTATION-2",1707345725,"02/07/2024 @ 16:42",1707336456,"02/07/2024 @ 14:07","#000000","#000000","Y",2,1
4868,50,"POL NET",1743960763,"04/06/2025 @ 12:32",1622827159,"06/04/2021 @ 12:19","#000000","#000000","Y",126,1
4869,50,"T: 120 DT: 4/6/25@10:33",1743953601,"04/06/2025 @ 10:33",1743953601,"04/06/2025 @ 10:33","#000000","#000000","N",0,1
4870,50,"T: 120 DT: 4/6/25@11:27",1743956846,"04/06/2025 @ 11:27",1743956846,"04/06/2025 @ 11:27","#000000","#000000","N",0,1
4888,50,"403RD RAMP NET",1743960739,"04/06/2025 @ 12:32",1597331045,"08/13/2020 @ 10:04","#000000","#000000","Y",176,1
4889,50,"T: 120 DT: 4/29/23@16:16",1682802994,"04/29/2023 @ 16:16",1682802994,"04/29/2023 @ 16:16","#000000","#000000","N",0,1
4894,50,"T: 120 DT: 4/29/23@19:15",1682813727,"04/29/2023 @ 19:15",1682813727,"04/29/2023 @ 19:15","#000000","#000000","N",0,1
4899,50,"T: 120 DT: 10/12/22@3:04",1665561896,"10/12/2022 @ 03:04",1665561896,"10/12/2022 @ 03:04","#000000","#000000","N",0,1
4900,50,"403RD MOC-1",1743964858,"04/06/2025 @ 13:40",1597331262,"08/13/2020 @ 10:07","#000000","#000000","Y",703,1
4905,50,"T: 120 DT: 4/6/25@12:06",1743965920,"04/06/2025 @ 13:58",1743959177,"04/06/2025 @ 12:06","#000000","#000000","Y",51,1
4918,50,"T: 120 DT: 4/6/25@12:29",1743960547,"04/06/2025 @ 12:29",1743960547,"04/06/2025 @ 12:29","#000000","#000000","N",0,1
PostPosted: Sat Oct 18, 2025 9:51 am
A few new talkgroups have come online on this system, but still totally encrypted.
4822,50,"POLICE DISPATCH",1760809365,"10/18/2025 @ 12:42",1597331186,"08/13/2020 @ 10:06","#000000","#000000","Y",1493,1
4866,50,"TRANSPORTATION-1",1760809140,"10/18/2025 @ 12:39",1597331147,"08/13/2020 @ 10:05","#000000","#000000","Y",936,1
4881,50,"T: 120 DT: 9/6/25@15:00",1757188859,"09/06/2025 @ 15:00",1757188859,"09/06/2025 @ 15:00","#000000","#000000","N",0,1
4900,50,"403RD MOC-1",1757188383,"09/06/2025 @ 14:53",1597331262,"08/13/2020 @ 10:07","#000000","#000000","Y",709,1
4903,50,"T: 120 DT: 10/18/25@12:39",1760809225,"10/18/2025 @ 12:40",1760809188,"10/18/2025 @ 12:39","#000000","#000000","Y",5,1
4907,50,"T: 120 DT: 10/18/25@12:33",1760808995,"10/18/2025 @ 12:36",1760808783,"10/18/2025 @ 12:33","#000000","#000000","Y",6,1
