It is currently Tue Apr 14, 2026 6:53 pm
 Post subject: Graphing radio usage
PostPosted: Sun Apr 09, 2017 11:35 am
I have DSD+ data dumped into excel. I want to make a graph illustrating how busy the repeater is.
how do I do it?
 Post subject: Re: Graphing radio usage
PostPosted: Sun Apr 09, 2017 5:38 pm
Nice try, but the data you suggest is nothing related to a system's capacity -- only that this channel was active at X:XX time. You'd need to dump the CC log into a text file and parse any relevant data. Then you'd have to find data that would prove your "system capacity usage" theory -- so the on/off time of each voice channel -- and then map the times that those channels are active.
It's not impossible but it's a lot more complex than you think. Also, I'm not even sure if DSD provides a "TIME OFF" value.
PostPosted: Sun Apr 09, 2017 5:44 pm
The data you suggest could be used to "imply" that X channel most active at X:XX time of day (in a 24 hour period) -- however, it's not capacity or time usage -- it'd be more like "channel hits" at X:XX time of day. I guess that would indirectly imply that there's voice activity on X channel.
So instead of a graph, you'd be looking more at a "heat map" kind of layout. (Except that the red color would indicate the most traffic...)
Something like this:
The data values on the left would represent "hits per hour" on X voice channel... but you'd have to do it for each voice channel. This is where it gets more complex... ;o)
PostPosted: Fri May 12, 2017 1:29 pm
Solved.
I figured it out.
Convert the time to an integer INT
Use a pivot table to Count vs Integer.
Than just graph what the pivot table spat out
this video helped a ton
https://www.youtube.com/watch?v=BvUwyP6oUYg
PostPosted: Fri May 12, 2017 3:21 pm
What exactly are you using for your Y data?
PostPosted: Sun May 14, 2017 1:39 pm
DSD+ spits out a "DSDPlus.srt" file
it contains an entry for every second the repeater is lit up:
22003
06:06:42,000 --> 06:06:43,000
2017/03/22 07:24:00
-DMR CC=11 Slot 1
22004
06:06:43,000 --> 06:06:44,000
2017/03/22 07:24:00
-DMR CC=11 Slot 1
22005
06:06:44,000 --> 06:06:45,000
2017/03/22 07:24:01
-DMR CC=11 Slot 1
22006
06:06:45,000 --> 06:06:46,000
2017/03/22 07:24:02
-DMR CC=11 Slot 1
22007
06:06:46,000 --> 06:06:47,000
2017/03/22 07:24:03
-DMR CC=11 Slot 1
