It is currently Fri Apr 17, 2026 1:53 am
 Post subject: What antenna...
PostPosted: Tue Jun 25, 2013 5:03 pm
Is this?
(On the Uniden).
 Post subject: Re: What antenna...
PostPosted: Tue Jun 25, 2013 5:22 pm
GPS....for location based scanning. You can set the lat long for specific systems in your scanner and the scanner will turn on and off systems within the radius to the mid point and range that you set.
PostPosted: Tue Jun 25, 2013 7:02 pm
No he means the rubber duck on the scanner.
It looks just like mine. :)
http://universal-radio.com/catalog/hamantht/2199.html
PostPosted: Tue Jun 25, 2013 7:19 pm
Aw crap. my apologize.
PostPosted: Tue Jun 25, 2013 8:01 pm
Maldol MH-209SMA
PostPosted: Tue Jun 25, 2013 8:07 pm
Yes that is the one I have. I bought mine years ago.
PostPosted: Wed Jun 26, 2013 7:16 am
Was it an improvement?
I thru a Diamond 815 on resulting in one less bar over VHF. Not tested above yet.
PostPosted: Wed Jun 26, 2013 11:05 am
It works and I'm happy with it. Probably about the same as the stock antenna just more manageable.
PostPosted: Wed Jun 26, 2013 11:15 am
This is by far the best wideband antenna for the 396xt or PSR-800:
http://www.scannermaster.com/WSMA_801_R ... 541178.htm
I have one in each SMA and BNC.
For compactness, I use Laird 866Mhz whip or a band-specific whip.
