Just wanted say thanks and recognize Joey on this forum for the work he did on my POV.
Drilled two holes, installed nmo mounts w/coax, which was the original scheduled plan. But then hooked up power, to not only my two Uniden scanners but the two remote heads to go with them, direct to the battery with a relay switch. This wasn't scheduled or planned out for, but he went ahead and did the work without batting an eye when I asked if it was possible.
Thanks again and it was also good to finally put a face to the name.
Also a big thanks to Brian for setting the whole thing up!
_________________ Richard Do you know Bunnery?
