It is currently Fri Apr 17, 2026 11:23 am
 Post subject: MPT1327 SME needed...
PostPosted: Mon Jan 30, 2012 9:55 pm
Is there an expert on these systems around that I could break bread with and learn from? I'm soon headed to a place where that seems to be the rule, and wanna try my hand at tracking them.
PM me, thanks.
PostPosted: Thu Feb 02, 2012 9:03 pm
No one?
PostPosted: Thu Feb 02, 2012 9:20 pm
Check your messages...
PostPosted: Sat Dec 15, 2012 12:08 pm
So, using Trunkview netted me a LOT of data, but no real clues where to go with it from here:
13:12:11 ******* TrunkView :: MPT1327 Protocol Decoder ------ Saturday 2012-12-15 ********
ID: 4101 | Unregistered | Cch Frequency: 451.21250 MHz
13:12:22 - CCSC | Control Channel System Codeword| SYS Id: 4101
13:12:22 - ALH | General single codeword | (000) Id: 0 Wt: 6 Rsvd: 0 M: 0 N: 0
13:12:22 - BCAST| Registration parameters | SYS: 4101 Spare: 0x1000
13:12:22 - BCAST| Call maintenance parameters | SYS: 4101 Per: No Ival: 0 Pon: No
13:12:22 - ALH | General single codeword | (000) Id: 0 Wt: 6 Rsvd: 0 M: 0 N: 10
13:12:23 - BCAST| Call maintenance parameters | SYS: 4101 Per: No Ival: 0 Pon: No
-----snip-----
13:14:49 - AHYC | Short data invitation message | (002) Org: 643 Tar: Short data message ident Slots: 3 Desc: 4
-----snip-----
Voice channels used:
Ch: 078 000.00000 MHz
Ch: 115 000.00000 MHz
Data channels used:
Adjacent sites:
ID: 4091 Ch: 211
ID: 40F1 Ch: 010
ID: 4221 Ch: 076
ID: 4231 Ch: 027
ID: 4239 Ch: 011
Announced control channels:
Withdrawn control channels:
Neighbour channels:
Idents logged:
(002) 643
(002) 652
(002) 653
(002) 668
(002) 729
(002) 798
(002) 6100
8185
8188
8189
Idents registered:
(002) 652
(002) 653
(002) 668
Registrations failed:
Voice targets called:
(002) 6100: 3 times
(002) 729 called: "(002) 6100"
(002) 798 called: "(002) 6100"
So now what?
PostPosted: Sat Dec 15, 2012 1:02 pm
So now what?
Start mapping channel numbers to frequencies.
PostPosted: Fri Jan 11, 2013 1:14 pm
This thread made me curious if we had any MPT1327 systems in the Olympia area. I'm hearing a control channel on 217.7425 PL:110.9. Trunkview is showing an ID of:51C1, with an adjacent site ID:5231 CH:074. The FCC license search didn't show anyone licensed on any of these frequencies. What setting are you using under "filters?" I'm still relatively new with this software. Setting it to "Show all Messages" makes it so there's too much data. "Show Minimal Messages" shows nothing, and "Set2" only shows "Vote now advice."
EDIT: Also, frequency 217.8425 PL110.9 ID:5119 is showing adjacent sites of:
ID:5231 CH074 (Same as above)
So:
217.7425=ID:51C1
217.8425=ID:5119
217.5675=ID:5169
Thurston County, WA
PostPosted: Fri Jan 11, 2013 1:49 pm
I'd bet that is PSE.
PostPosted: Fri Jan 11, 2013 2:27 pm
Interesting. I'll definitely be keeping an eye on this. The system seems pretty dead so far but I've only had it running for about 2 hours. I'll continue to let it run and report back with anything I find.
Thurston County, WA
PostPosted: Fri Jan 11, 2013 2:38 pm
I'll scan that range later today and see if I can pick up anything. I would imagine their new system is in testing...
PostPosted: Fri Jan 11, 2013 2:47 pm
If so then, exciting! I love mapping new systems, and this is even a new protocol (to me). I just got unitrunker running along side trunkview. Still nothing so far but we will see. I'll keep it running 24/7 through next week at least.
Thurston County, WA
