It is currently Fri Apr 17, 2026 7:05 am
PostPosted: Fri Jul 01, 2011 8:04 pm
Had my new car a total of 3 hours before I started itching for antennas. Today, I went to Spectrum Communications over in Moses Lake to have Brian put a hole in it. I chose to off-center this antenna, as it's primarily going to be for scanner use. The next one will be on the opposite side of the roof, and be VHF-high band to a as-yet undetermined radio.
Pic-1: An overview; plate and cat's face obscured for security reasons.
Pic-2: The antenna mount, with customer-supplied VHF high antenna, centered at 155.500 mhz.
Pic-3: Where the antenna cable ends up. Comes down from the roof, avoids the side curtain airbags, runs under the upholstery/jamb, then under the driver's seat area and into the center console.
Pic-4: There's about 3 feet of slack in the business end of the cabling, terminated in a BNC crimp. I wanted this much slack so I can put a handheld radio anywhere, as I'm considering a ProClip dash mount. The cabling runs through a factory "port" in the console up to where I need it; the other cable is an audio patch cable that runs into the factory auxilary input (visible in Pic 3).
Findings:
Inside Brian's shop in Moses Lake, a steel frame building, I was picking up a WSP air unit running traffic enforcement on Car-1, for ground units west of Ellensburg (Thorp exit). Enough said.
Once again, Brian and Spectrum Communications have proven their worth. The job they did on my last vehicle was superb; this time I was once again impressed by the attention to detail, the consultation with me at every step of the way, and the end result. I will not hesitate to drive halfway across the state again for their service.
Thanks again, Brian!
PostPosted: Fri Jul 01, 2011 8:14 pm
LMR-200 is great. I soldered my connectors though.
PostPosted: Fri Jul 01, 2011 11:14 pm
I know that Glock key fob from somewhere?
Nice job Brian! :chaingun:
PostPosted: Sat Jul 02, 2011 12:54 am
FYI you can get a nice black version to match your other antenna. Roughly about $15 from WPS Antennas.
PostPosted: Sat Jul 02, 2011 6:28 am
Glock's aren't supposed to go in the dryer.
Looks good.
PostPosted: Sat Jul 02, 2011 8:35 am
I actually have a USPS mailer tube or two chock full of antennas. That one was the one I happened to throw in the car to take with. I mostly use my Comtelco tri-bander.
PostPosted: Sat Jul 02, 2011 8:46 am
Looks like a good install, I need to find a newer P25 VHF with a remote head to fit in my console. The F1020 is not going to be listenable much longer.
PostPosted: Sat Jul 02, 2011 9:13 am
:D
Or like Mick Jagger says "Paint it black".
PostPosted: Sat Jul 02, 2011 9:20 am
Too bad you ruined the antenna with a Subaru
PostPosted: Sat Jul 02, 2011 9:23 am
Says the mini van driver?
PostPosted: Sat Jul 02, 2011 9:39 am
I think he drives a 2500 HD.
PostPosted: Sat Jul 02, 2011 11:28 am
Not to take away from my experience at Spectrum, but I have my doubts about the City of Moses Lake. While I was there Thursday, someone banged into my car door and left a nice divot at the Subway. Later that night, someone found it hilarious to steal my windshield wiper blades at the hotel.
Kids, man. Damn kids.
PostPosted: Sat Jul 02, 2011 11:29 am
I didn't mean his county slacker vehicle...
PostPosted: Sat Jul 02, 2011 12:47 pm
Damn! I was sure those wiper blades would fit my car but they didn't.
I know that antenna will fit. :chaingun:
PostPosted: Sat Jul 02, 2011 1:06 pm
I was thinking about it, and I don't think that was quite what was meant when the phrases "bring ENOUGH gun" and "One is none, and two is one" were coined. Image
