It is currently Fri Apr 17, 2026 4:51 pm
 Post subject: Got new tires....
PostPosted: Sat Apr 23, 2011 12:21 pm
And they were kind enough to not check the antenna clearance when they put the truck up on the lift...thanks for "forgetting" to tell me you bent my antenna.
I had the work done at Frank's Tire Factory in Union Gap.
 Post subject: Re: Got new tires....
PostPosted: Sat Apr 23, 2011 12:47 pm
Last time I dropped my car off at Les Schwab I got it back with the Check Engine light on. Their response: "Huh, you should get that fixed."
At least their warranty is sound.
PostPosted: Sat Apr 23, 2011 9:11 pm
At least they didn't bend the sheet metal... Get up there and straiten that thing out! :mrgreen:
Guy at the muffler shop almost took out the glass on their roll up door with my lowband antenna today...
PostPosted: Sun Apr 24, 2011 2:31 am
I need a couple nmo's on my pick-em-up.
Did you install?
PostPosted: Sun Apr 24, 2011 4:52 pm
Brian and I installed...never drilled a hole but I've done everything else. Moses Lake is close....right?
:beer:
PostPosted: Sun Apr 24, 2011 8:09 pm
:beer:
yabut; I don't think I've been out that way since I talked to him about it.
If I'm going to rip down the headliner I wanna put in two NMO mounts at the same time.
Of course.
