It is currently Fri Apr 17, 2026 1:08 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: DIY tips (non-radio)
PostPosted: Fri Feb 25, 2011 10:52 am
Just a tip, because I'm bored.
Been using dryer lint as fire starters when camping, especially winter/snow camping.
Take the cardboard tube from toilet paper rolls, put a square of paper towel over one end, rubber band it on tightly. Stuff it with dryer lint as you wash clothes. When full and packed tight, run a layer of glue (I use glue sticks) over/around the top rim, put a square of paper towel over that end, rubber band it until it sets. Take the band off the bottom end and repeat the process.
Burns like a mall on fire.
Wife has been talking about adding pencil shavings to the mixture. Another additive I've been contemplating adding is the results from a paper shredder at work, one of those that shreds sheets into an almost sand-like product (NSA 02-01 standard).
DON'T add the dryer sheets!
 Post subject: Re: DIY tips (non-radio)
PostPosted: Fri Feb 25, 2011 11:18 am
Neighbor was shaving bark off pine logs to make playground equipment for his kids. I asked and took all the shavings, baked them on low heat for 20 minutes in a deep pan, then bagged them in gallon Zip-Loc bags.
Thought about it, and added dessicant packs to each bag.
Bought a one-pound bag of gun safe dessicant at Sportco in Fife ($8 or so), and had the wife sew up 8 small cotton bags. Filled each with 2oz of the dessicant, 6 went in bags of the shavings, the other two each went into a safe.
PostPosted: Fri Feb 25, 2011 11:53 am
Thanks for the tip, sounds very simple. We will start ours this weekend.
PostPosted: Fri Feb 25, 2011 4:53 pm
I heat with wood and camp all the time, so make my own homemade starters. The past 3-4 years I've been collecting old candles and hitting up the Thrift stores (Goodwill, St. Vincent) for large candles. Found several 3-4 lb candles recently at Goodwill for $2. I save all my empty cardboard egg cartons. You can buy parafin canning wax at the store, but that's gets a little too $$$ for me.
Every 6 months or so I melt down all the candles in a coffee can/water bath on the stove. Fill the egg cartons with dry chain saw shavings and fill them with melted wax. Cut up the carton once the wax hardens and in a ziplock bag they go. Work great and burn for 10-15 mins.
PostPosted: Fri Feb 25, 2011 5:02 pm
If you run low on dryer lint thermite does a pretty fair job :chaingun:
http://www.youtube.com/watch?v=SU8iRYbnAb0
Try this when snow camping :D
http://www.youtube.com/watch?v=BnHR4cMX ... re=related
PostPosted: Fri Feb 25, 2011 5:20 pm
Pallets, used motor oil, some diesel, and a propane torch ignited with a Vaseline soaked cotton ball.
(Straight from the Boy Scout Hand-Book).
PostPosted: Fri Feb 25, 2011 5:32 pm
PostPosted: Fri Feb 25, 2011 5:53 pm
Thermite's more fun for destroying documents....And tanning.
DAMHIK.
PostPosted: Fri Feb 25, 2011 5:58 pm
Jim, I think Wil is talking about, starting a fire, not blowing his A@@ up.
and the fact here this is a great plan, lint, go figure.
cheap, most have some, or can get some.
PostPosted: Sat Feb 26, 2011 7:35 pm
Some need look no further than their very own belly button.
PostPosted: Sun Apr 24, 2011 12:08 pm
Tip- if you're cycling your laptop battery overnight by letting it lapse into sleep mode, unplug the external cooling fan/mat. Oh, the battery will die...
SAOAFR.
PostPosted: Sun Apr 24, 2011 1:14 pm
Tip- buckets like these are not step stools
PostPosted: Sun Apr 24, 2011 1:19 pm
Has the swelling gone down yet?
PostPosted: Sat Jun 25, 2011 1:04 pm
Don't clean a BBQ grill while wearing khaki pants.
Hey, I was in the zone, and not paying attention...
PostPosted: Thu Dec 08, 2011 8:47 pm
Don't wait until it's 33* outside to clean your garage gutters, and don't wait 5 years.
