It is currently Sun Apr 19, 2026 7:37 am
 Post subject: Investment prop
PostPosted: Mon May 10, 2010 7:39 pm
I may have an opportunity to purchase a ten unit apartment unit.
Thoughts?
Anyone do this?
 Post subject: Re: Investment prop
PostPosted: Mon May 10, 2010 8:28 pm
Thoughts?
Anyone do this?
Are you good at unplugging toilets ? :D
PostPosted: Mon May 10, 2010 9:53 pm
Keep in mind that properties are generally overvalued in most areas (including yours). The OFHEO and Case-Shiller home price indexes are your friend.
See here: http://www.housingbubblebust.com/OFHEO/Major/NorthWest.html
Notice the general direction of property values (i.e. nosedive) and the fact that they are still selling in bubble territory above the inflation index.
Given the huge amount of existing inventory and pending foreclosures due to idiot-loan rate resets...
See here: http://www.doctorhousingbubble.com/wp-content/uploads/2010/05/option-arm-chart.gif
Its safe to say that property values will continue on a downward spiral. So... I wouldn't bother unless its an incredible deal.
PostPosted: Tue May 11, 2010 7:35 am
I was using:
(rate of return / cost) = %
to compare.
Plus all the extra unforeseen cost.
Yeah, probably not worth it.
The owner is 80-something, just wants to "retire".
PostPosted: Wed May 12, 2010 8:47 pm
I was using:
to compare.
I have a co-worker who has 1 or 2 of these himself.
Managed properly, the can o' worms is not always so messy.
Are you a gamblin' man?
PostPosted: Thu May 13, 2010 11:31 am
I am not. This one needs some work, I will pass. Not enough return.
PostPosted: Thu May 13, 2010 4:31 pm
Wow! Think of all the money you just saved. Now you can buy a new radio or some fishing gear or both. :D
PostPosted: Thu May 13, 2010 7:56 pm
I'm due for a new bike.
PostPosted: Thu May 13, 2010 8:08 pm
Well there you go. :D
