It is currently Thu Apr 23, 2026 8:51 pm
PostPosted: Wed Mar 03, 2010 12:46 am
PostPosted: Wed Mar 03, 2010 7:12 am
There are three reasons for the holes:
* If you were to take apart an outlet and look at the contact wipers that the prongs slide into, you would find that they have have bumps on them. These bumps fit into the holes so that the outlet can grip the plug’s prongs more firmly. This detenting prevents the plug from slipping out of the socket due to the weight of the plug and cord. It also improves the contact between the plug and the outlet.
* Electrical devices can be "factory-sealed" or "locked-out" by the manufacturer or owner using a plastic tie or a small padlock that runs through one or both of the prong holes. Construction projects or industrial safety requirements may require this type of sealing. For example, a manufacturer might apply a plastic band through the hole and attach it to a tag that says, "You must do blah blah blah before plugging in this device." The user cannot plug in the device without removing the tag, so the user is sure to see the instructions.
* There also is a small savings in raw materials (metal) for the manufacturer of the actual plug prong. Every little bit helps!
PostPosted: Wed Mar 03, 2010 7:15 am
I was going to guess it makes jerry rigging a jumper cord easier as you can wrap the wire around the hole...
PostPosted: Wed Mar 03, 2010 8:56 am
I thought they were vent holes that allowed air to pass thru to keep the plug cool, like the vent holes in a rotor for a car .
PostPosted: Wed Mar 03, 2010 11:38 am
Why do doughnuts have holes?
PostPosted: Wed Mar 03, 2010 11:53 am
Give them credit :D
http://home.howstuffworks.com/two-flat- ... -holes.htm
Also found this...
http://cr4.globalspec.com/thread/7948
Everything you ever want to know about plugs....
http://users.telenet.be/worldstandards/electricity.htm
PostPosted: Wed Mar 03, 2010 2:14 pm
haha wondered if anyone would mention that.. I was lazy and thought eh.. .who cares haha
Users browsing this forum: Google [Bot] and 3 guests
