It is currently Mon Apr 20, 2026 8:35 am
PostPosted: Wed Feb 10, 2010 2:00 pm
Some interesting antennas also on this site :D
http://radiowavz.us/html/mbitr_tvas.html
PostPosted: Wed Feb 10, 2010 9:05 pm
That's interesting.
Of course the first thought that comes to mind is one question on my Tech test that asked (something like) "What frequency range is considered MOST HARMFUL to human beings."
The answer, of course, is 30MHz - 300MHz
And this antenna is designed for 30MHz - 88MHz
Of course limiting TX power will help.
I think conventional wisdom considers something around 5-7 watts of VHF to be "safe".
On the other hand, I wonder how well the radio is going to radiate at that freq range with an antenna up against the body.
There is a guy that goes to Dayton every year with an NMO mount + antenna on a hard hat. Functional, of course.
PostPosted: Wed Feb 10, 2010 9:15 pm
Do you remember the little clip mount for a rubber ducky that you could clip on your hat? :D
PostPosted: Thu Feb 11, 2010 12:30 am
I have a hard time buying from anyone who can't spell correctly.
The antenna is made of UVPVC coated copper clad stranded steel. Antenna assembly can be totally submerged is water proof (accept connectors).
75$ for a piece of coax, a connector, and some heat shrink tubing.
:beer:
