It is currently Sun Apr 19, 2026 9:44 pm
PostPosted: Fri Nov 06, 2009 3:15 pm
http://gizmodo.com/5398588/telephone-co ... -this-lamp
it's pink however
PostPosted: Fri Nov 06, 2009 3:28 pm
Lets see... 48 volts and, say, 60mA (which is being generous for modern telephone lines) gives you about 3 watts. The real wattage would be less given the voltage drop a telephone line gets under load. Of course be sure not to use it on a voice line as 15mA will take the circuit off-hook and draw a dial tone.
In the good ol days you could suck down a good 100-120mA depending on the C.O. gear.
I suppose its a good product for those who are hard up for a couple of watts.
PostPosted: Sat Nov 07, 2009 8:17 pm
it's for the people that believe that a USB cup warmer can keep your coffee warm at a blistering 2.5 watts.
