It is currently Sat Sep 19, 2026 8:32 pm
 Post subject: HF Multicoupler
PostPosted: Tue Feb 28, 2017 7:05 pm
I'm looking for a receiver multi coupler so I can hook my 4 or 5 receivers to my single HF antenna.
Anyone have any reviews or personal experience with receiver multi couplers for use below 30 MHz?
- Chris
Chris Parris
Federal Wavelengths columnist
The Spectrum Monitor Magazine
chrisparris@thefedfiles.com
 Post subject: Re: HF Multicoupler
PostPosted: Wed Mar 01, 2017 5:58 pm
Check these out Chris.
http://www.stridsberg.com/prod01.htm
PostPosted: Wed Mar 01, 2017 6:21 pm
Yep best in the biz. Expensive but worth it.
PostPosted: Tue Mar 07, 2017 4:04 pm
Totally agree and recommend these units, by far the best bang for the buck. You won't find a lesser expensive option with nearly the same build quality..... will not happen!! I've been using these couplers for many years without issue. The one time I inadvertently connected a trunked radio that affiliated with its system (mind you that these are receive only multicouplers), Stridsberg repaired and sent back the unit within a few days, on their dime.
Unless you're made of money, Stridsberg is the only way to go.
-Marcus
PostPosted: Tue Mar 07, 2017 4:32 pm
Thanks for all the recommendations!
- Chris
Chris Parris
