It is currently Sat Aug 29, 2026 4:37 am
PostPosted: Fri Feb 22, 2019 10:41 am
I have been getting a very weak DMR signal on 478.2875
However i cannot find a license with the DMR emission for this frequency in the entire country
The signal is so weak that even the CC does not decode but can confirm it is DMR
This is being received from Nassau county NY so i suppose the signal could be coming from PA, NJ , CT or even possibly MA
PostPosted: Fri Feb 22, 2019 11:46 am
Could it be an image?
PostPosted: Fri Feb 22, 2019 8:09 pm
I suppose it could as there is alot of DMR activity in the 470 range
I also have heard morse code on the freq in question so hopefully i can get a recording and possibly decode it...
PostPosted: Tue Mar 12, 2019 5:08 am
Here is the recording of the morse code ID -
File comment: morse code ID of 478.2875
PostPosted: Tue Mar 12, 2019 7:26 am
It is WPEE697 which comes up as a long-expired callsign out of Missouri.
Of course the FCC database is down (as usual) this morning however looking at our local copy of it I see there is 478.2875 with a callsign of WPEE681 iicensed to Airsite Communications out of Brooklyn (search for 478.2875 at http://www.interceptradio.com/fcc.php ). The callsign is close enough that it likely is not coincidental. Perhaps someone entered it wrong on their repeater equipment.
PostPosted: Tue Mar 12, 2019 8:33 am
Thank you very much Rich i appreciate it
I think there may be some type of decoder i can get for SDR i will look into that
Thanks again :)
