It is currently Sat Aug 29, 2026 5:33 pm
 Post subject: Talk groups
PostPosted: Sun Jul 12, 2015 4:36 pm
I have a lot of talk groups to put in my scanner . How is it done the easy way. Bob.
 Post subject: Re: Talk groups
PostPosted: Sun Jul 12, 2015 8:33 pm
What model is it?
PostPosted: Mon Jul 13, 2015 5:41 am
I have the uniden BCD396T.can you help me? If I wanted to put say 13288 talk group in to the radio, how or what buttons do I use?. Bob.
PostPosted: Mon Jul 13, 2015 12:40 pm
Which system are you trying to listen to?
PostPosted: Mon Jul 13, 2015 1:16 pm
I would like to put the talk groups for ANNE ARUNDEL POLICE AND FIRE FREQ.. Bob.
PostPosted: Wed Jul 15, 2015 5:49 am
Without having the scanner in front of me to get the keystrokes correct, basically you want to -
create a system ("AA Co" or such, type = Motorola Type2)
add control channel freqs (854.3375,854.4125, 854.8125, 855.1625)
add a group ("PubSafety" or whatever)
add talkgroup IDs to the group (13288, 18032, ...)
PostPosted: Wed Jul 15, 2015 3:33 pm
From Mark's Scanners:
Press Menu. At 'Program System' press E/yes.
At 'Select System' scroll to 'New System' and press E/yes.
At 'Select Sys Type' scroll to 'MOT' and press E/yes.
Scroll to the type of Motorola system you want to program and press E/yes.
I'm fairly certain the system has rebanded, so use '800MHz Custom'. If that doesn't work, use '800MHz Standard'
At 'Confirm?' press E/yes.
At 'Edit Name' press E/yes. See Entering Text.
Scroll to 'Set Frequencies' and press E/yes.
At 'New Frequency' and press E/yes.
At 'Input Frequency' enter the frequencies Flash provided (one at a time) and press E/yes.
At 'Edit Frequency' press Menu and scroll down to 'New Frequency', then press E/yes. Repeat to program the rest of the trunking frequencies.
Press Scan to exit.
This will create the system and will pass audio for any traffic on the system. You can create groups and add IDs so you'll only hear the traffic you want to hear (and will see appropriate text on the display for each talkgroup).
