It is currently Tue Sep 22, 2026 4:13 pm
PostPosted: Thu Mar 17, 2022 10:38 am
I have a Motorola Astro 'Clean Cab' locomotive radio in need of repair from a small shortline and hoping someone here can point me to a shop that would be able to work on it. I do know this radio is long out of production.
Issue is somewhat simple but beyond what I am capable of repairing. It has a audio amp issue where you turn up the volume past a low level the speaker makes horrid, distorted sounds. Low volume is OK, but using it at levels needed for in-cab use is not possible.
Any and all suggestions welcome.
Thanks!
-Kevin
PostPosted: Sat Mar 19, 2022 8:18 am
Hey Kevin,
Bruce Lane (KC7GR) is the Spectra guru. Bruce runs Blue Feather Technologies which is in Kent, Wa. He's been downshifting his business for the past several years, but he's still the man. http://www.bluefeathertech.com/
Best of luck with the Clean Cab...
-Marcus
