It is currently Thu May 07, 2026 11:58 pm
 Post subject: Motorola system ID's
PostPosted: Mon Feb 03, 2020 1:16 pm
Motorola system ID's are usually in the format of something like "7Axx" for example
But is it possible for them to be in any other format such as only 3 digits and no letters?
 Post subject: Re: Motorola system ID's
PostPosted: Mon Feb 03, 2020 4:11 pm
3 digits or characters would be a P25 system. Like the new WSP 700 system is now 9CC. 4 digits are the older analog/digital systems.
PostPosted: Tue Feb 04, 2020 4:19 am
So that would be only a fully P25 system? Because i understand that some Motorola analog/type 2 or whatever systems can have P25 capable talkgroups on them
Whats happening is i am receiving a weak Mot control channel and when i sit on the control channel to try and get a system ID it just reads "ID: xxx " Whereas usually when a system ID is decoded it will show "SID:xxxx" so i am also thinking this could be some type of error due to the weak signal
PostPosted: Tue Feb 04, 2020 11:46 am
Exactly, here in MA we have One Network, with the ole Type II running as 0D14 and the P25 running as D14
0D14 is analog with a few P25 TG's which are allowed on only a handfull of Talk Paths
PostPosted: Wed Feb 05, 2020 1:19 pm
The three digit hex System ID's are usually assigned to true P25 systems using a P25 9600 baud control channel.
The four digit System ID's are assigned to Motorola systems. They may have some digital talk groups but are not broadcasting a true P-25 control channel.
Harris system P-25 ID's are three digits as well, but are often not unique. They seem to use a default system ID of 00A a lot, but with different WACN.
-CP
Chris Parris
Federal Wavelengths columnist
The Spectrum Monitor Magazine
chrisparris@thefedfiles.com
PostPosted: Thu Feb 06, 2020 11:28 am
Makes sense - must have been some type of error due to the weak signal
Thanks
