It is currently Fri May 08, 2026 2:20 pm
PostPosted: Tue Aug 30, 2016 3:38 pm
When I purchased my GRECOM PSR-800 several years ago I successfully downloaded the supplied install application on my PC running XP. I've been away from scanning since then and wanted to load the application on my new PC running Windows 10. When I attempt to install the application from the CD I get an error message. Is this old application not compatible with Windows 10? Any suggestions would be greatly appreciated. Thanks.
PostPosted: Wed Aug 31, 2016 12:35 pm
http://www.greamerica.com/download/EZSc ... _v1.08.zip
This is the last version made for the PSR-800... give this a shot. If this doesn't work then try the Whistler version below:
https://whistlergroup.com/products/ez-s ... 080-ws1088
PostPosted: Wed Aug 31, 2016 6:23 pm
Thanks, I appreciate the help. I'll let you know if it works.
Best Regards,
Bruce
