It is currently Tue May 12, 2026 1:51 pm
 Post subject: BCD436HP scanning issue
PostPosted: Mon Feb 15, 2016 9:52 am
So I finally pulled the trigger and got a BCD436HP, but have come across an issue. I created one FL list for Pierce Cty Law enforcement TGIDs and one FL for Pierce Cty Fire TGIDs. However the FL fire list doesnot seem to work. When I ID search on the Pierce Cty LE list it picks up the fire channels but when I jump to the dedicated fire FL it doesn't pick up anything. I have gone through both the scanner and sentinel to make sure that something isn't turned off, and when it scans I see the data symbol. Any thoughts?
PostPosted: Mon Feb 15, 2016 1:58 pm
Part of the problem is that I may still be linear like the old system. I wanted one fl with pierce law enforcement (the two phase II systems and couple of others) and the equivalent fire. But when I ran id search it would pickup TGIDs that I know we're in the database so then I copied those in and avoided them so maybe the problem lies somewhere in there.
PostPosted: Mon Feb 15, 2016 4:32 pm
Under Sentinel,
Click on Edit at the top of the screen.
Then Click on Add Channels of Range
Under Service Types Check all of them and reprogram your scanner that will enable to here all the talk groups.
