It is currently Fri May 08, 2026 12:01 am
 Post subject: Uniden Audio Logging
PostPosted: Wed Nov 19, 2014 12:02 pm
I'm setting up a new PC to do audio logging of analog conventional freqs. This has turned out to be a major PITA.
Setup:
Some flavor of a Dell Optiplex with a bona fide serial port, confirmed to be COM1.
BCD396XT
Attempt 1:
bcTool. Works great, logs all the hits, but no audio recording.
Attempt 2:
IDTrackerIII. Won't connect to the scanner and won't tell me why it can't connect.
Attempt 3:
FreeSCAN. Tried to test the connection and "FreeSCAN could not communicate with the scanner, or the scanner is not recognized as being compatible. Response received: -1"
Attempt 4:
Advanced Virtual Control. Nice UI, but again won't connect to the scanner.
I made sure to close down each program so they weren't fighting over the serial port.
 Post subject: Re: Uniden Audio Logging
PostPosted: Wed Nov 19, 2014 12:14 pm
IDTracker 3 can be a little persnickety to set up, but works awesome once you have it going.
PostPosted: Wed Nov 19, 2014 12:33 pm
Did you make sure the 396XT with FreeScan has the OFF setting of C-CH Output? If it's ON or EXTENDED it won't be detected by FreeScan.
Like you said, in the BIOS, make sure it's set to COM1 -- not AUTO.
Are you connecting with the serial cable only -- not USB?
PostPosted: Wed Nov 19, 2014 1:05 pm
What are those steps to set up?
Yes, turned it off. Funny that bcTool works with it on.
Password protected BIOS :(
Yes, straight serial.
PostPosted: Wed Nov 19, 2014 2:02 pm
Hmm my guess is that the COM port is set to AUTO in the BIOS. That can a lot of issues in Windows...
PostPosted: Wed Nov 19, 2014 2:51 pm
Hell if I know. I haven't had any issues with it on the new computer, but I don't use Uniden radios either.
PostPosted: Wed Nov 19, 2014 2:55 pm
DeviceMangler will at least tell you the COM port number, even if it keeps changing in Auto.
I use Butel s/w, seems to work fine. My biggest hassle is that the Unidens don't put everything out on the serial port, and they often get a little behind: the logged freq/tone don't always match what was recorded (leading the software to incorrectly label the file).
PostPosted: Wed Nov 19, 2014 2:57 pm
When you start the program, does it auto connect to the scanner? Or do you need to click something? I assume the "connect" functionality is the menu item where Stop is shown in this screenshot:
Yeah, that's where I got the COM port number.
PostPosted: Wed Nov 19, 2014 3:06 pm
You may need to re-create the image file from the scanner to the program. It should do it automatically (mine does) when you click "track".
PostPosted: Wed Nov 19, 2014 3:19 pm
And how do you create the image file? Might be a moot point since the log is filled with this:
Code:
ConnectScanner - Error (5): CommOpen COM1 (CreateFile) - Access is denied.
I wish there was something like this for serial ports.
PostPosted: Wed Nov 19, 2014 3:20 pm
PostPosted: Wed Nov 19, 2014 5:24 pm
BIOS shows the serial port as COM1, not Auto.
PostPosted: Wed Nov 19, 2014 6:20 pm
Good.
You can always try a USB to serial converter. It might work better.
BTW, on a similar note, I had an issue with mine acting up for a while. I discovered it was the end connector that Uniden uses. I bought my 2nd 396xt used and the previous owner gave me the true USB cable. The end connector just wore out after so many connects/disconnects.
Silly question but what version of Windows are you using? If it's Win7 or Win8 do you have admin privileges?
PostPosted: Wed Nov 19, 2014 7:07 pm
7 x64 and I do have admin rights. I have a Prolific USB to serial adapter and hopefully I'll be able to do the F8 method to bypass the unsigned drivers.
PostPosted: Wed Nov 19, 2014 7:30 pm
You shouldn't need to bypass anything. The drivers are on Windows Update. It should install them upon first plug in.
