It is currently Fri May 08, 2026 12:07 pm
 Post subject: Emission Designators
PostPosted: Wed Nov 05, 2014 1:08 pm
I just added a couple to the list.
http://www.interceptradio.com/wiki/inde ... esignators
Any corrections, or any others that are common and should be added?
 Post subject: Re: Emission Designators
PostPosted: Wed Nov 05, 2014 4:37 pm
If I remember correctly this should cover most analog comms:
25k0F3E = 25khz bandwidth, 5khz deviation, used for 450mhz broadcast links
20K0F3E = 20khz bandwidth, 15kc channel spacing, 5khz deviation HAM/GMRS/NOAA/Marine "Wideband"
16K0F3E = 16khz bandwidth, otherwise the same as 20K0F3E, legacy UHF Wideband, sometimes this is used for GMRS
11K0F3E = 11.25khz bandwidth, 12.5kc channel spacing, 2.5khz deviation Commercial/FRS "Narrowband"
