It is currently Fri May 08, 2026 7:07 pm
 Post subject: Motorola XTS Experts
PostPosted: Wed Oct 08, 2014 3:49 pm
I asked on the other forum and didn't get any solid replies. I found a curious issue with my XTS 2500 and was just wondering if this is normal behavior with the Motorola firmware...
I was programming some UHF HAM repeaters into my radio (via FPP) and noticed that the Rx CTCSS wasn't working... After some head-scratching, I switched the bandwidth from 25khz to 12.5khz and the Rx CTCSS is now working fine...
My XTS has the R17.01.01 firmware.
 Post subject: Re: Motorola XTS Experts
PostPosted: Sat Dec 13, 2014 9:38 pm
Is this an ALT radio? Has it been aligned/'benched'?
PostPosted: Sun Dec 14, 2014 8:00 am
And what is the firmware version?
PostPosted: Sun Dec 14, 2014 12:31 pm
I don't know what ALT means. I can't speak to the latter but it seemed to work 100% and my audio quality sounded perfect when using P25 or analog modes.
So, the original post is a bit old. Shortly after that post, I upgraded both my XTS 2500 and 5000 to the latest R20 release using the FlashZap method -- and then reloaded the codeplug manually (as recommended so that the codeplug is migrated to the latest version.)
I am noticing some issues with stored memories after the upgrade on both radios.
New question: is there a way (in the CPS software) to reset the radios to a "factory fresh" state -- wiping all stored user data/memories? With all of the WSP/HAM changes, I need to reprogram them anyway.
PostPosted: Sun Dec 14, 2014 12:59 pm
You could find a blank code plug on another site and blow it in.
PostPosted: Sun Dec 14, 2014 10:45 pm
I'm betting it needs to be aligned. I PMed you my guess as to why. :D
PostPosted: Fri Dec 19, 2014 12:10 pm
RX Side of the radio was not properly decoding CTCSS? Can you "align" that?
PostPosted: Thu Dec 25, 2014 9:56 pm
The hint he gave is that it happens in narrow but not wide..
If hes a hair off frequency..
Same thing happens on trunked systems...control channel sounds perfect when programmed as a conv rx freq but decode rate is like 20% when you attempt to set it as a control channel to follow the system.
You'd be surprised how finicky some things are when they're off freq.
Human ear can't tell, but the decoder circuit sure can.
