It is currently Tue May 12, 2026 6:39 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Post subject: Tuesday POTUS visit
PostPosted: Sat Apr 19, 2014 5:04 pm
Lots going on Tuesday. Multipal Marine One helo's arrived at Arlington airport today.
 Post subject: Re: Tuesday POTUS visit
PostPosted: Sun Apr 20, 2014 10:13 pm
FAA to establish VIP TFR over Everett/Arlington, WA on Tuesday, April 22, 2014
A NOTAM has been issued that will affect flight in the area during President Obama's planned visit.
30 NM RADIUS TFR
Location
On the PAINE VOR/DME (PAE) 163 degree radial at 0.8 nautical miles.
From the surface up to but not including 18000 feet MSL.
Times
12:00 noon local until 1:45 pm local Tuesday, April 22, 2014
4:15 pm local until 5:30 pm local Tuesday, April 22, 2014
8 NM RADIUS NO-FLY ZONE
Location
From the surface up to but not including 18000feet MSL.
Times
12:00 noon local until 1:00 pm local Tuesday, April 22, 2014
4:30 pm local until 5:30 pm local Tuesday, April 22, 2014
10 NM RADIUS NO-FLY ZONE
Location
On the PAINE VOR/DME (PAE) 358 degree radial at 15.3 nautical miles.
Times
12:30 pm local until 1:45 pm local Tuesday, April 22, 2014
4:15 pm local until 5:15 local Tuesday, April 22, 2014
30 NM RADIUS TFR
Location
On the PAINE VOR/DME (PAE) 014 degree radial at 25 nautical miles.
Times
1:15 pm local until 4:45 pm local Tuesday, April 22, 2014
Location
Times
1:15 pm until 4:45 pm local Tuesday, April 22, 2014
Affected Public Use Airports
KPAE Snohomish County (Paine Fld)
S43 Harvey Field
W10 Whidbey Air Park
S60 Kenmore Air Harbor Inc
W16 Firstair Field
KAWO Arlington Muni
W55 Kenmore Air Harbor
0W0 Seattle Seaplanes
83Q Port of Poulsbo Marina Moorage
S86 Sky Harbor
13W Camano Island Airfield
KBFI Boeing Field/King County Intl
0S9 Jefferson County Intl
8W5 Apex Airpark
W36 Will Rogers Wiley Post Memorial
KRNT Renton Muni
KOKH Aj Eisenberg
KSEA Seattle-Tacoma Intl
2S1 Vashon Muni
1S2 Darrington Muni
3W5 Mears Field
KBVS Skagit Rgnl
Additional Notes:
No pilots may operate an aircraft in the areas covered by this NOTAM (except as described).
Except as specified below and/or unless authorized by ATC in consultation with the air traffic security coordinator via the domestic events network (DEN):
A. All aircraft operations within the 8 NMR and/or 10 NMR area(s) listed above, known as the inner core(s), are prohibited except for: military aircraft directly supporting the United States Secret Service (USSS) and the office of the President of the United States. Coordinated and approved law enforcement, air ambulance and firefighting operations must receive approval prior to entering this airspace at 206-214-4722 to avoid potential delays. Regularly scheduled commercial passenger and all-cargo carriers operating under one of the following TSA-approved standard security programs/procedures: Aircraft Operator Standard Security Program (AOSSP), Full All-Cargo Aircraft Operator Standard Security Program (FACAOSSP), Model Security Program (MSP), Twelve Five Standard Security Program (TFSSP) All Cargo, Or All-Cargo International Security Procedure (ACISP) and are arriving into and/or departing from 14 CFR Part 139 airports.
B. For operations within the airspace between the 8 MNR and/or 10 NMR and 30 NMR area(s) listed above, known as the outer ring(s): All aircraft operating within the outer ring(s) listed above are limited to aircraft arriving or departing local airfields, and workload permitting, ATC may authorize transit operations. Aircraft may not loiter. All aircraft must be on an active IFR or VFR flight plan with a discrete code assigned by an air traffic control (ATC) facility. Aircraft must be squawking the discrete code prior to departure and at all times while in the TFR and must remain in two-way radio communications with ATC.
C. The following operations are not authorized within this TFR: flight training, practice instrument approaches, aerobatic flight, glider operations, seaplane operations, parachute operations, ultralight, hang gliding, balloon operations, agriculture/crop dusting, animal population control flight operations, banner towing operations, sightseeing operations, maintenance test flights, radio controlled model aircraft operations, model rocketry, unmanned aircraft systems (UAS), and utility and pipeline survey operations.
D. FAA recommends that all aircraft operators check NOTAMS frequently for possible changes to this TFR prior to operations within this region.
PostPosted: Mon Apr 21, 2014 5:02 am
Looks like he will be taking a tour of the mudslide area.
PostPosted: Mon Apr 21, 2014 10:03 pm
Help! Last time the Pres was in town I posted a bunch of freq's from other visit's. Now I can't find it and don't remember what I called the post...
PostPosted: Tue Apr 22, 2014 5:29 am
Put 165.375 into search on here and you will get some stuff.
PostPosted: Tue Apr 22, 2014 8:02 am
SERS PSOPS N4 is active with radio chatter associated with the visit.
Sounds like it's patched to LERN
PostPosted: Tue Apr 22, 2014 9:28 am
Some active frequencies so far:
300.525-Oregon ANG - Reach12, Bigfoot, Angel 12
298.3
317.6- Seattle Center
379.1-Bullseye Radio
349.4-McChord Command (Helos)
270.3-Seattle Center
229.725-Air to Air?
246.475
288.4- WADS - Deer Hunter, Wizard
276.4- Gray AAF (Helos)
364.2-WADS Bigfoot calling Sierra, Wizard Alpha signal check
303.1-Wizard Alpha
I'll add to this as more pop up. Expected wheels down around 1230. Don't forget the KPAE frequencies. He's flying to Asia after so keep an ear on the ATC frequencies as he departs to the West.
Thurston County, WA
PostPosted: Tue Apr 22, 2014 10:59 am
Bob from Portland reports that there is a U2 overhead
PostPosted: Tue Apr 22, 2014 11:21 am
Just picked up AF1 on 128.5!!!
Thurston County, WA
PostPosted: Tue Apr 22, 2014 12:01 pm
Air Force One landing at Paine a few min ago.
http://youtu.be/TIUPgrgms28
PostPosted: Tue Apr 22, 2014 12:10 pm
Thanks again to Bob in Portland. Backup AFl landed a half hour ago in Spokane. I would guess that they will fly within 30 minutes of eachother to Japan.
PostPosted: Tue Apr 22, 2014 12:14 pm
Just heard an aircraft come up on UHF guard (243.0) couldn't make out what was said.
Thurston County, WA
PostPosted: Tue Apr 22, 2014 12:16 pm
If you are the smart guy flying 3/4 of a mile into the restricted zone do you really think he's (100%) listening to to you shoo him off on 121.5?
PostPosted: Tue Apr 22, 2014 12:18 pm
Hopefully the fighters off his wing will get his attention.
Thurston County, WA
PostPosted: Tue Apr 22, 2014 12:19 pm
That didn't take long. Neat video though, thanks for sharing.
Thurston County, WA
