It is currently Sun May 10, 2026 12:04 pm
 Post subject: Puget Sound Energy
PostPosted: Mon Jul 01, 2013 1:29 pm
Has anyone heard any of the 153.xxx MHz freqs licensed to PSE used lately?
I see they have renewed all of them in the last month.
I have not heard any use of the usual 153.545 in my area.
 Post subject: Re: Puget Sound Energy
PostPosted: Mon Jul 01, 2013 5:12 pm
I should check 158.130 but 153.635 has been quiet for months now... If they renewed the licenses one might usefully monitor them all and see what pops up on them in the future.
PostPosted: Mon Jul 01, 2013 5:46 pm
Nope, I think they have moved to their new MPT system. (Their waiver expires Oct 1st.)
I posted a similar question on the PSE MPT thread. I haven't heard them in ages.
PostPosted: Mon Jul 01, 2013 7:37 pm
153.545 is still active in Olympia
PostPosted: Mon Jul 01, 2013 7:38 pm
Searched the 153.xxx band today for PSE and nothing heard.
Switched to search 217.000 to 218.000 at about 7:30 pm.
Locked out data channels and found:
(approximate freqs)
217.510 CW ID
217.375 CW ID
217.485 CW ID
217.780 VOICE
217.830 VOICE
217.895 VOICE
217.995 VOICE
(ALL WERE SAME VOICES!)
Sounds local and is PSE for sure. I am monitoring from Bellingham.
Will keep searching that range and report further info.
PostPosted: Fri Jul 05, 2013 12:51 pm
Monitoring today I find that 217.830 & 217.995 are both on at the same time with same comms.
Suspect 217.830 is the input & 217.995 is the repeater out since 217.995 is stronger in signal.
Also noted that 217.780 & 217.895 seem to be a pair with 217.895 being the repeater out.
Update:
I have programmed my scanners for 217.8975 & 217.9975 and I think I can hear all the local PSE stuff that way.
Both sets have the same comms but not at the same time. They use the same vocal IDs that they used
on 153.545 here in Whatcom county (North 2).
PostPosted: Fri Jul 05, 2013 2:39 pm
The 220 MHz band did not have to be Narrowband Compliant so if you look for frequencies on it for PSE set your scanner up for plain old FM :wink:
PostPosted: Fri Oct 04, 2013 7:24 pm
Getting close call hits all over Pierce & Thurston on 217.62
PostPosted: Fri Oct 04, 2013 7:52 pm
That's a family radio frequency! (Just kidding) :D
PostPosted: Fri Oct 04, 2013 8:02 pm
and it's 10-4 day, ok?
PostPosted: Fri Oct 04, 2013 8:24 pm
Ya got that right good buddy - comeon! :mrgreen:
