It is currently Mon May 11, 2026 10:03 am
PostPosted: Tue Apr 30, 2013 3:22 pm
Do Motorola trunked systems not have TX inhibit so people can't walk over each other?
PostPosted: Tue Apr 30, 2013 5:23 pm
Supposed to. If your part of a group you should not be able to key the radio if someone else in your group has the floor. If they both come up at the same time I don't know how the system would decode them.
PostPosted: Tue Apr 30, 2013 6:29 pm
It's a system wide setting. Up to the admin to decide.
PostPosted: Tue Apr 30, 2013 10:57 pm
Guess Ill go re-view my class docs. Don't remember that part.
PostPosted: Wed May 01, 2013 9:19 am
It's an officer safety issue. If an LEO or Fire needs helps now, they don't have to wait for the air to be clear. If they do walk over each other, the dispatcher just tells that unit to standby.
PostPosted: Wed May 01, 2013 9:36 am
The particular system I was listening to is licensed for only one repeater location. Would be interesting to see what that would sound like with voters.
PostPosted: Fri May 03, 2013 2:31 pm
If someone has a stuck Mike other people can still transmit and be heard.
