It is currently Sun May 24, 2026 4:06 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Grant county
PostPosted: Thu Dec 27, 2012 11:59 am
hi all its been a while since i Posted but I got a question what type of system is grant county going to be switching to edacs Motorola or P25, :beer:
 Post subject: Re: Grant county
PostPosted: Thu Dec 27, 2012 1:05 pm
Is this the one you are referring to:
http://publicsafety.taitradio.com/news/ ... Washington
PostPosted: Thu Dec 27, 2012 1:11 pm
Will be able to monitor it with my pro 106 ? :beer:
PostPosted: Thu Dec 27, 2012 2:19 pm
Won't be able to say. You'll have to wait until the system is up and running. Anytime before is purely speculation. If they use Phase II, then no you won't. If they use encryption, then no you won't.
PostPosted: Thu Dec 27, 2012 2:50 pm
thanks for the info
PostPosted: Thu Dec 27, 2012 4:19 pm
PSR-800 will do Phase II
PostPosted: Thu Dec 27, 2012 9:46 pm
"The new system also enables migration to P25 phase 2."
Looks like it will go in as phase 1 and change to phase 2 later.
Wiz
PostPosted: Fri Dec 28, 2012 8:26 am
whats phase 1 and phase 2 ? :starwars:
PostPosted: Fri Dec 28, 2012 11:03 am
http://www.danelec.com/pdfs/TG-001-3-0- ... 0Guide.pdf
PostPosted: Sun Dec 30, 2012 9:30 pm
It's up and operational. Check DB for frequencies. P25 Phase I is the type. 100% Tait equipment.
Most of programming for Law is completed and then on to fire. Infrastructure and subscriber units are installed.
Shooting for cutover mid-January.
Keep in mind that Fire 1, Fire 2, Law Data and Law Dispatch will be patched to their current VHF frequencies. I've logged 71 TGID's. 95% of Law TGIDs are encrypted. (I would hope for a system of this magnitude that they'd spring for encryption.)
PostPosted: Mon Dec 31, 2012 2:24 pm
is it Motorola or edacs :?: :shock:
PostPosted: Mon Dec 31, 2012 2:33 pm
P25 is digital.
He says it's using Tait equipment. :D
PostPosted: Mon Dec 31, 2012 3:53 pm
is P25 edacs or Motorola :beer:
PostPosted: Mon Dec 31, 2012 3:55 pm
Neither. P25 is an open spec.
PostPosted: Mon Dec 31, 2012 4:49 pm
I have in Mot and I am Picking up IDs :beer:
