It is currently Thu May 21, 2026 12:12 pm
 Post subject: NARROWBAND IN 2013
PostPosted: Mon Nov 26, 2012 9:45 am
Do all FM freqs have to go to narrowband in 2013?
It looks like just VHF HI & UHF bot not VHF LOW or 700 or 800.
Just 150 to 512.
http://transition.fcc.gov/pshs/public-s ... nding.html
 Post subject: Re: NARROWBAND IN 2013
PostPosted: Mon Nov 26, 2012 10:52 am
PRO-106
PostPosted: Mon Nov 26, 2012 1:44 pm
Your good to go, the 106 does do narrow band, and yes no narrow banding for vhf-low.
Radio Shack Pro-197
PostPosted: Mon Nov 26, 2012 3:27 pm
Thanks, I know it has narrowband. Just wanted to know what freqs would need to be changed to narrowband.
So everything from 150 to 512 MHz but not some of the paging freqs.
PostPosted: Mon Nov 26, 2012 3:31 pm
Marine and Ham are staying with wide...yes?
PostPosted: Mon Nov 26, 2012 5:29 pm
The Narrowbanding Mandate does NOT apply to Low Band (30-50 MHz) 220, 700, 800 or 900
MHz Part 90 systems, nor to FRS, GMRS, MURS, Amateur, Marine VHF, or CB radio users.
PostPosted: Mon Nov 26, 2012 7:52 pm
Never mind. I might be seen as grumpy or something like it. :roll:
900 LMR is already narrow and started life that way.
PostPosted: Mon Nov 26, 2012 8:44 pm
The FRS frequencies are already narrowbanded.
The MURS three 151MHz frequencies ARE narrowbanded but the two 154MHz frequencies ARE NOT narrowbanded.
151.820 MHz (11.25 kHz)
151.880 MHz (11.25 kHz)
151.940 MHz (11.25 kHz)
154.570 MHz (20.00 kHz)
154.600 MHz (20.00 kHz)
PostPosted: Wed Nov 28, 2012 3:19 pm
FCC Doc. on narrowbanding.
Users browsing this forum: No registered users and 22 guests
