It is currently Tue Feb 17, 2026 8:19 am
PostPosted: Tue Mar 29, 2005 7:15 pm
Don't set off the EMER button of the portable radio you just lifted.
http://www.komotv.com/stories/36007.htm
It tends to piss off the on duty crew.
PostPosted: Wed Mar 30, 2005 8:12 am
But it's so bright and orangy looking.....it just has to be pressed!
PostPosted: Thu Mar 31, 2005 10:58 am
I knew that little button had a good use somewhere!
PostPosted: Tue Apr 05, 2005 6:46 pm
What does EMER stand for?
 Post subject: EMER Button
PostPosted: Tue Apr 05, 2005 8:58 pm
The EMER button is on most radios today. In most cases it's an orange button. When pushed it transmits an emergency signal to the dedicated dispatch center. The dispatcher receives the ESN (a identification number) number and thru a data base can identify the person that the radio is assigned to. Firefighters and Police officers use this system when there in trouble. These smart individuals pushed the button on the radio and set off the alarms in dispatch. Dispatch realized they had an emer activation from a radio that wasn't assigned to a call. They called the station to see what the problem was.
PostPosted: Mon Apr 11, 2005 9:32 pm
Ya, I understand what the button is for but what I am curious about is what EMER stands for.
PostPosted: Tue Apr 12, 2005 6:41 am
EMERgency
