It is currently Fri May 08, 2026 2:22 pm
 Post subject: Any ideas who this is?
PostPosted: Sun May 06, 2012 8:43 pm
IG WQPF535
KPMG LLP
[APPLICANT IS IN THE SECURITY MAINTENANCE OPERATIONS FOR FINANCIAL FIRM RADIOS WILL BE USED FOR EVACUATION IN CASE OF AN EMERGENCY]
Control Point 1 - 811 MAIN ST, HOUSTON TX 713-319-2159
(link)
05/02/2012 License Issued
1 - ATLANTA (FULTON) GA 2.0 km radius around center point (map)
456.4875 MO 4p 4e 11K2F3E
456.5125 MO 4p 4e 11K2F3E
457.4875 MO 4p 4e 11K2F3E
457.8625 MO 4p 4e 11K2F3E
457.7625 MO 4p 4e 11K2F3E
2 - BOSTON (SUFFOLK) MA 2.0 km radius around center point (map)
456.4375 MO 4p 4e 11K2F3E
456.6125 MO 4p 4e 11K2F3E
457.6625 MO 4p 4e 11K2F3E
456.6625 MO 4p 4e 11K2F3E
3 - CHARLOTTE (MECKLENBURG) NC 2.0 km radius around center point (map)
451.7625 MO 4p 4e 11K2F3E
457.0625 MO 4p 4e 11K2F3E
457.1375 MO 4p 4e 11K2F3E
457.1875 MO 4p 4e 11K2F3E
457.3125 MO 4p 4e 11K2F3E
4 - CHICAGO (COOK) IL 2.0 km radius around center point (map)
451.2375 MO 4p 4e 11K2F3E
452.1875 MO 4p 4e 11K2F3E
456.2375 MO 4p 4e 11K2F3E
5 - DENVER (DENVER) CO 2.0 km radius around center point (map)
456.3375 MO 4p 4e 11K2F3E
456.7375 MO 4p 4e 11K2F3E
457.0875 MO 4p 4e 11K2F3E
457.6875 MO 4p 4e 11K2F3E
6 - DETROIT (WAYNE) MI 2.0 km radius around center point (map)
456.6875 MO 2p 2e 11K2F3E
457.7875 MO 4p 4e 11K2F3E
457.8125 MO 2p 2e 11K2F3E
457.8625 MO 2p 2e 11K2F3E
7 - HOUSTON (HARRIS) TX 2.0 km radius around center point (map)
456.3875 MO 4p 4e 11K2F3E
456.4625 MO 4p 4e 11K2F3E
456.6875 MO 4p 4e 11K2F3E
456.4125 MO 4p 4e 11K2F3E
8 - KANSAS CITY (JACKSON) MO 2.0 km radius around center point (map)
457.4125 MO 4p 4e 11K2F3E
457.8875 MO 4p 4e 11K2F3E
462.5125 MO 4p 4e 11K2F3E
467.5125 MO 4p 4e 11K2F3E
9 - MINNEAPOLIS (HENNEPIN) MN 2.0 km radius around center point (map)
456.5625 MO 4p 4e 11K2F3E
457.1125 MO 4p 4e 11K2F3E
457.1625 MO 4p 4e 11K2F3E
10 - MOUNTAIN VIEW (SANTA CLARA) CA 2.0 km radius around center point (map)
456.2875 MO 4p 4e 11K2F3E
462.4875 MO 4p 4e 11K2F3E
467.1875 MO 4p 4e 11K2F3E
467.4625 MO 4p 4e 11K2F3E
11 - NEW YORK (NEW YORK) NY 2.0 km radius around center point (map)
456.5875 MO 4p 4e 11K2F3E
12 - NEW YORK (NEW YORK) NY 2.0 km radius around center point (map)
13 - PORTLAND (MULTNOMAH) OR 2.0 km radius around center point (map)
456.6375 MO 4p 4e 11K2F3E
451.3625 MO 4p 4e 11K2F3E
14 - SEATTLE (KING) WA 2.0 km radius around center point (map)
15 - SHORT HILLS (ESSEX) NJ 2.0 km radius around center point (map)
16 - ST. LOUIS (ST. LOUIS CITY) MO 2.0 km radius around center point (map)
456.5375 MO 4p 4e 11K2F3E
456.7125 MO 4p 4e 11K2F3E
17 - MCLEAN (FAIRFAX) VA 2.0 km radius around center point (map)
456.3625 MO 4p 4e 11K2F3E
PostPosted: Sun May 06, 2012 8:52 pm
Just what the applicant says. A financial Auditing firm. Global if I rememebr correctly
PostPosted: Sun May 06, 2012 9:11 pm
Looks like someone had a meeting about safety and figured they might need radios...
PostPosted: Wed Oct 05, 2016 7:38 pm
Looks like someone had another meeting and figured that they didn't need them anymore...Or decided they needed to upgraded to be safer
http://seattle.craigslist.org/see/ele/5813280908.html
PostPosted: Wed Oct 05, 2016 7:48 pm
I would say that was a BearCom sale. Same repeater and antenna is on roof of Sacred Heart in Spokane, which interestingly enough has a NXDN system. Security is dispatched out of Portland and radios are all MotoTRBO and they hate them.
PostPosted: Wed Oct 05, 2016 7:56 pm
Why did they hate them?
PostPosted: Wed Oct 05, 2016 8:50 pm
Because they're not made by Kenwood?
Wocka Wocka Wocka!
PostPosted: Wed Oct 05, 2016 10:46 pm
I would say Day Wireless is a couple blocks away.
The Federal Detention Center is even closer but they're still using their UHF P25 trunked system.
PostPosted: Thu Oct 06, 2016 6:29 am
Wocka Wocka Wocka!
Easy there fonz...I understand that Sacred Heart is extremely difficult to cover with one site, yet BearCom sold them 1 repeater and a mediocre antenna. I believe there is a low power site in the basement as a fill in. Half of that building is built into the side of the hill.
PostPosted: Thu Oct 06, 2016 8:37 am
Wocka Wocka Wocka!
The VA in Seattle used to have a scattering of yagis on the roof pointed downward to help fill in areas of the complex that couldn't get covered otherwise.
PostPosted: Fri Oct 21, 2016 12:01 am
Hasn't anyone heard of Radiax leaky cable. The Rainer Bank building uses a single repeater and leaky cable down an elevator shaft down to the underground levels with an antenna in the basement and a single outside antenna on the roof. Works great with 2 watt portables any where in the building or downtown area. At least it did years ago.
PostPosted: Fri Oct 21, 2016 6:57 am
Last year I suggested running ethernet cables down the elevator shaft in a 25 year old building to the CCTV guy. He said that was against code :/
PostPosted: Fri Oct 21, 2016 7:21 am
It absolutely is.
Variances can be (and are) granted in specific cases. Most cases I've worked with required cables in elevator shafts to be contained within conduit
The only exception I have seen to that is leaky coax, for obvious reasons.
Try mounting ANYTHING that is not a part of an elevator / elevator controls in an elevator machine room ....
PostPosted: Fri Oct 21, 2016 11:16 am
Yes - correct. They have fire proof Radiax leaky cable that does meet all local and national fire and building codes. (That is what we used) But I have no idea about internet type cable. I would think that there must be some type of telephone / ethernet cable that is fireproof and meets code.
"Back in the stone age" when Seattle Police & Fire were on UHF -- it was hit or miss on radio coverage - from inside some of the buildings in the downtown area. It all was a matter of "how" and "what" the building was made of. When 800 MHz came along -- they still had some problems -- but a lot less "inside" building communications problems and better radio signal levels all around the downtown area and all through the newer and taller buildings all over the city.
The old Ozark Hotel fire back in the 1970's made everyone in the city of Seattle as well as the entire US of A -- sit up - and take notice of the need to make new laws and new needed safety products to protect everyone from needless fires such as the Ozark Hotel.
When you check into a hotel on your next vacation trip somewhere - and your hotel room has a Fire Detector in it - it is because of the Ozark Hotel fire and the City of Seattle Fire codes.
I turn the soapbox over to someone else now. MTM
PostPosted: Fri Oct 21, 2016 2:14 pm
Thus, I spend a great part of my day with my face buried in iBwave, designing DAS in hopes of making a difference. Yes, just like Michael Knight, but without the cheese, and the talking car. When it comes to in-building signal reinforcement, the NFPA and IFC guidelines typically rule.. Although the ego of the AHJ ends the day.
-Marcus
