It is currently Fri May 15, 2026 5:28 am
 Post subject: ACARS
PostPosted: Tue Mar 13, 2012 5:43 pm
I have just learned about ACARS and I live less than 1 mile from the south end of Paine Field. Does anybody have a dedicated ACARS setup? I have tried a few programs for the pc and one for the Mac but nothing seems to be consistant. :-) Thx for any info.
Josh
 Post subject: Re: ACARS
PostPosted: Wed Mar 14, 2012 5:24 am
I use PDW for POCSAG decoding and it works well. Just checked and it also supports ACARS decoding.
http://www.gsm-antennes.nl/PDW/pdw.php?lang=eng
PostPosted: Wed Mar 14, 2012 11:18 pm
I'm a big fan of ACARSD myself.
PostPosted: Thu Mar 15, 2012 3:36 am
hell
I can do acars decoding via an app on my iphone
http://itunes.apple.com/ca/app/acars/id386825917?mt=8
works great if you have the volume just right on the radio
PostPosted: Wed Mar 21, 2012 2:52 pm
Thanks guys for the info. I am trying out a few different applications and a few different radios. Not quite figured out the best, less expensive setup or best way to decode the MSG. I'll report back shortly after I try out another scanner.
PostPosted: Thu Mar 22, 2012 11:09 am
I use ACARSD for the messages, but I also use PlanePlotter for the map.
Thurston County, WA
PostPosted: Mon Mar 26, 2012 3:22 am
if you really like acars messages and have a hf receiver with ssb mode you should try hfdl
there is a program that work very well at decoding hfdl.
the program is called PC-HFDL
(note pc-hfdl can be tied in to google earth map to show you where in the world the aircraft is )
http://www.chbrain.dircon.co.uk/
ttp://www.kloth.net/radio/hfdl-monitoring.php
http://www.youtube.com/watch?v=Bm0vzZ9zMrE
hfdl messaages are similare to acars messages...alot of it is coded but ther are some plain text messages similar to vhf acars messages..some very strange .. you just have to be quick at catching them before the next message is sent either from another aircraft or the ground station
xjf79
PostPosted: Mon Mar 26, 2012 6:47 pm
Ok I have PlanePlotter and ACARSD running. Next is to read the manual. :-) I am getting the msgs but need to do some work on getting more info than just the tail number and time stamp. :-) I'll report back soon. Thanks again everyone.
p.s. I downloaded PC-HFDL and have it running but I need to connect a HF receiver still. :-)
PostPosted: Mon Mar 26, 2012 6:51 pm
and PDW 3.1
