It is currently Fri May 15, 2026 12:49 am
PostPosted: Tue Feb 08, 2011 7:12 pm
Both the RS PRO106 and the new GRE PSR-310 are object oriented scanners.
WIN500 can be used to program both of these scanners.
My question is.... can The PRO106 be cloned into the GRE PSR-310 with the jumper cable hooked between
their programming jacks?
I realize the PRO106 is a digital capable scanner and the PSR-310 is analog but if there are only analog frequencies programmed into the PRO106 will I be able to clone them from the PRO106 to the PSR-310?
I am sure it can be done using WIN500 but it would be simpler just to clone if possible.
Thanks in advance for any input.
PostPosted: Thu Feb 10, 2011 5:48 pm
I tried to do this today and when the cloning cable was connected between the PRO106 and the PSR-310 neither scanner would recognize then other.
Cloning can't be done by this method.
Will try by using WIN500.
