It is currently Sat Feb 21, 2026 11:05 am
PostPosted: Fri Dec 03, 2004 11:03 am
Hello all...
Looking for some input. I just picked up a Pro 95 and am very happy with it. Now I am looking for a small Trunking scanner that I can use to replace my old school Pro 2026 that I have mounted in my car.
The dimentions of the 2026 are as follows.
Dimensions:.............................1 5/8 x 6 5/16 x 7 3/8 Inches (HWD)
Does anyone know of a trunking scanner thats about the same size? The depth is not a concern. The Uniden and Radio Shack base type scanners are all too big to fit in the location I have in my car.
Thanks
PostPosted: Sat Dec 04, 2004 10:35 am
Rodentkj wrote:
Hello all...
Thanks
Have you checked the Uniden BCT8? That one is a little bit smaller than the more common BC7xx line, I believe.
Dan
PostPosted: Sat Dec 04, 2004 11:45 am
The new uniden 246 looks really sweet and it's small.
PostPosted: Sun Dec 05, 2004 12:17 pm
I checked out the specs on the BCT8 and it is still to large for the area where I want to mount it. And the 246 is a handheld. I'm looking for something thats more like a base model. ANy other suggestions / models / manufactures I could look in to?
 Post subject: Small Trunking Scanner
PostPosted: Mon Dec 06, 2004 9:58 am
I have a BC 780 that is attached to a remote head adapter kit that I purchased earlier this year.
This unit is compact as the body part can be installed in another location and just the keyboard part is mounted wherever you want.
This item can be viewed at http://www.scannermaster.com and on the left side of the page, click on remote and read the details of item number RSC-1 Remote Head Kit.I purchased both the scanner and the kit already put together.
PostPosted: Mon Dec 06, 2004 12:39 pm
The BCT8 is the smallest mobile TrunkTracker I know of. I remember the Pro-2026. I think one generation of them was called the "Patrolman" or something like that. Very neat at the time. I had one for a while.
I'm with the other guy above: A remote-mount BC780 might be your best bet if you don't have any larger spots, but that's serious cash. Any way the spot can be enlarged? You'd be surprised how clever you can get with a dash.
Here's some pictures of a "scanner hole" being created where a "scanner hole" doesn't belong - in MY dash no less!
http://www.ccomm911.com/Veharc/veharcdec02.htm
Dan
