It is currently Wed May 13, 2026 2:25 am
 Post subject: yaesu frg-9600 Reciever
PostPosted: Wed Jul 07, 2010 3:18 pm
http://www.rigpix.com/yaesu/frg9600.htm
Bought one for $35 I'll get it on Monday. Anyone have one? I know it has good and bad reviews.
PostPosted: Wed Jul 07, 2010 3:32 pm
Can't go wrong for that price.
PostPosted: Wed Jul 07, 2010 6:24 pm
I had one over 20 years ago, it was a great rig for mil-air. It was not the best scanner in the world,but it is way more than that. I also had the video card in mine. I remember having it out at Hillsboro in 89 (give or take a year) to watch the Blue Angels.
Jim
PostPosted: Thu Jul 08, 2010 2:44 pm
You paid 35 bones? It works? = You done der good!!
PostPosted: Thu Jul 08, 2010 3:28 pm
Yes it works but over 400mhz he said it was a little weak. I didn't care about that, something about it I had to have it. It was a "radio-thing"
PostPosted: Thu Jul 08, 2010 3:53 pm
Well, if it works... Actually they all are a bit "deaf" above 460 Mhz...
but nothing a good, low-noise preamp couldn't fix...
I have two of them...
Both have the NTSC video output... Great for ATV RX!!! The PLL on both of mine get a bit "wonky" at less than 13VDC going in the power hole, but, having the all-mode RX capability (including SSB!:-) has sure been fun over the years...
One I keep on the "test bench" to listen to stuff... The other sits right next to the PRO 2006 and under a Kenwood RZ-1! Remember those???
My RZ-1 has a dead display but by playing "blind man" I can usually load a single frequency into it and "park" it there... usually WSP area...
Eric
KB7DQH
PostPosted: Sun Jul 11, 2010 11:14 am
Did the mod on it now it gets 20-950 mhz. Need an antenna, didn't come with one.
What would be a good antenna?
Does it need to be an outside one?
PostPosted: Sun Jul 11, 2010 5:47 pm
Mod??? I guess I will have to research that...
Outside antennae always better... Discones do wide bandwidth but are unity gain... Use the lowest loss feedline you can "afford"... Bear in mind I have scavenged 1-5/8" hardline I can use... and commercial antennas!!!
One thing I plan on doing to mine one day is changing out the SO 239 connector and replacing with Type N... Should help out the loss issue above 400 Mhz...
Eric
Kb7DQH
PostPosted: Sun Jul 11, 2010 7:03 pm
The mod I used here:
http://www.kb2ljj.com/data/yaesu/frg-9600.htm
00-999mhz but only 20-950 what the reciever uses.
For right now I'm going to get an adapter from ratshack so I can use a scanner antenna ....UHF to BNC
PostPosted: Mon Jul 12, 2010 5:24 am
Eric
Kb7DQH
Why not use an adapter from ratshack
http://www.radioshack.com/product/index ... Id=2103353
PostPosted: Mon Jul 12, 2010 7:45 pm
tonyclark wrote:
Eric
Kb7DQH
An N connector is much better above 400MHz. The PL259 and SO239 are very old in the design, some would argue anything above 50MHz should use not them. I'm not that critical of them myself though, as long as they are put on correctly and the coax not damaged by heat they are still good up to the 460 range.
Jim
PostPosted: Mon Jul 12, 2010 10:24 pm
Yeah, what he said... :nobs:
Eric
KB7DQH
