It is currently Wed May 13, 2026 4:28 am
PostPosted: Sun Jun 13, 2010 7:25 pm
After the recent Freemont Fire I was thinking it might be interesting to set up a scanner to Record Tactical Fire Talk Groups. Like for SNOPAC I would set it up to record Tac 2, 4, and 6. What is the best way to Record ?
I know you can use computer software or some scanners have Line Out to a Tape Recorder?
PostPosted: Sun Jun 13, 2010 8:57 pm
I use ID Tracker 3. Patch cable from the scanner audio output to the line in/mic jack, records through the sound card into neatly sperated files. It's been a lifesaver for ID'ing seldom used stuff.
PostPosted: Sun Jun 13, 2010 11:54 pm
bcTool is decent if you have a Uniden DMA scanner.
PostPosted: Mon Jun 14, 2010 7:35 am
I use this program to record my live feeds.
http://www.snooper.se/
It has voice activated recording. And it can be setup to start a new file after a specific file size is reached. Which is nice when editing or trying to locate a specific incident via time.
I also run a script that deletes files that are more than 10 days old. So the drive does not fill up with audio files.
PostPosted: Fri Jun 18, 2010 1:41 am
can anyone suggest a way to record audio while in the field?
PostPosted: Fri Jun 18, 2010 1:48 am
A laptop or a voice recorder with line in.
Or be like a podcaster and get one of those grossly overpriced solid state recorders. I'll keep using this.
