It is currently Thu May 21, 2026 11:29 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: reaonably priced antenna
PostPosted: Sat Jan 16, 2010 5:27 am
At the moment I'm using a magnetic mount antenna on the roof of my mobile home, which is working fine, but I would like to get a little more height. Is there an antenna that isn't expensive that will get the frequencies in this area of east Peirce county?
I have an old UHF/VHF antenna on the shop, but it doesn't do well on the 800 band. It's seen too many years of weather too.
Thanks~
PostPosted: Sun Jan 17, 2010 10:54 am
I'm not sure what type of antenna your looking for. I can tell you that I own 3 of Radio Shack's http://www.radioshack.com/product/index ... Id=2103641 antennas and they perform well in all areas. I can't speak for the geographics in Pierce County, but those work fine here! And at $30, they're reasonable.
If you want a true discone, their http://www.radioshack.com/product/index ... Id=2103160 priced at $75 I've heard works wonders too.
PostPosted: Sun Jan 17, 2010 5:35 pm
Not to take away from Joeys post as the Discone is a good antenna, but here is a fairly good place to look at what is out there and then see what fills your needs.
http://www.universal-radio.com/catalog/scanants.html
I have seen many posts where guys are using this one specifically and seem to praise its performance,
http://www.universal-radio.com/catalog/ ... /2732.html
Good luck!
PostPosted: Sun Jan 17, 2010 7:07 pm
Also don't skimp on the coax. If it's over a 50' run you will want to use something like LMR400, or 9913. Don't buy Tandy cable at all.
Jim
PostPosted: Mon Jan 18, 2010 4:49 am
Thanks for all that information, as I'm more of a casual listener I think that Radio Shack antenna will do the job for me.
Would there be any reception problems if I mounted this antenna on the same pole as the TV antenna and ran the cable down along side the TV cable?
Thanks again~
PostPosted: Mon Jan 18, 2010 7:39 am
Shouldn't be, as both will be 'receive' only.
PostPosted: Mon Jan 18, 2010 9:56 am
I forgot to add...yes...low loss cable will make a big difference! The 400 cable is kind of expensive but it's worth it.
PostPosted: Mon Jan 18, 2010 12:32 pm
Expect to spend from .75 cent to $1.50 a foot for LMR4000.
Jim
PostPosted: Mon Jan 18, 2010 7:01 pm
Outdoor VHF-Hi/UHF Scanner Antenna
Model: 20-176 | Catalog #: 20-176
$26.99
100 feet of $1.50 a foot for LMR400.
$150.00
Getting the frequencies in this area of east Peirce county.
$ Priceless :D
PostPosted: Mon Jan 18, 2010 7:27 pm
Hi
I live in Shelton on Hood canal and i am using the antenna craft SC2 mounted on a 10 foot piece of pvc pipe and i can receive all the trunking from Seattle, Tacoma, and Bellevue area using my Uniden BC-996T
PostPosted: Tue Jan 19, 2010 12:37 am
I think HRO sells LMR400 for about 80 cents a foot. Far as I am concerned anything under 1.00 is a good investment.
PostPosted: Tue Jan 19, 2010 4:57 am
The antenna is in my budget's range, but that coax is not. Guess I better stick with what I've got, it works well enough although not great.
Thanks so much for all the information.
PostPosted: Tue Jan 19, 2010 5:01 am
How far of a run do you want to do?
PostPosted: Tue Jan 19, 2010 7:07 am
The antennacraft antenna comes with RG-6 which is inexpensive and has reasonably low loss. For some antenna runs I use LMR-240 which is much easier to deal with than LMR-400.
PostPosted: Tue Jan 19, 2010 7:20 am
Well, I have used RG6 for feedline before and it does work pretty well for both RX and TX applications (you get an SWR of only 1.5 in theory for TX but I could somehow get 1.3/1.4 and it worked great. It is a option.
LMR-240 is good option too; last I checked, its 25 cents less per foot than LMR-400 but I could be wrong.
Users browsing this forum: No registered users and 31 guests
